How much increased SOTP can I expect from switching from 3.23 rear to 3.90 ? I have a '04 A4 LS1 with Corsa Cat Backs, K&N aftermarket intake. I'm also planning on a COW tune. Thanks for the help!
I have 3.90's in my '04 M6, one of the best mods I've done.
If you are consideing a gear swap also consider a hardened out-put shaft install while you are making the change. The shaft is the weak link in the drive train, if you mod your ride and hook up well on the street or track the shaft is the 1st thing to go.
Good luck in your gear swap decesion, let us know how you go.
[QUOTE=Dark-Knight]I have 3.90's in my '04 M6, one of the best mods I've done.
I would only do the 390 with the M6. Would be to much for the
A4, I think.
I'm going with the 3:42's. Seems to be the best all around setup. I think 3:90's are too much gear for an A4. Even 3:73's are too much. Some drag racers I spoke with are going back to the 3:42's because they lost a few MPH on their trap times. Just my opinion.
The concensus seems to be 3:73's with my A4 then right? Do I still need the hardened input shaft then? Also, is the swap from 3:15's to 3:73's worth the $ in overall acceleration improvements during low end and mid-range? Thanks again guys for all the help and inputs!!!!!!
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Where are you located? I thought you posted in another thread that it is somewhere in NY. If you're near NYC you might be able to get a ride in a few cars that already have the gears you'd like. There seems to be quite a few modded C5s down there.
I think the t/c has a TON to do with how the car will run with steeper gearing. I have an SS3600 and went with 3.42's.... In hindsight, I should have installed 3.73's with this t/c. ORRRR, go with a stall closer to 2600 - 3000 rpm. Just my opinion, the car is a MONSTER on the track @ launch time, but around town driving can be frustrating when going 30 mph up a hill @ damned near 3,000 rpms. UGH!!!
Thats exactly what I don't want! I want the car to be TOTALLY driveable like it is now in the real world, but with more SOTP acceleration when I decide to punch it whether it be from a complete stop or 30 MPH.
if your not going to do forced induction like supercharger, 3.73 is pefect!
I have 4.10s in my MN6 and im glad i went with it despite people here saying its too much. I still get 31 mpg highway.
What was it like going from the 3:42's to 4:10's? I'm thinking about doing that myself. Can't decide between 3:90's and 4:10's. Probably not going to go crazy with mods. Next up is LT's. If I do H/C it will be a mild set-up.
