Help !!! I am getting wind noise that appears to be coming from the drivers side of the Clear Top. What can I do to stop it or at least make it less noticeable ???
Go to his Corvette Site, then to the "How To" section and you'll see a couple of links for window tip-in adjustment and window blowout plug adjustment, both of which are supposed to minimize wind noise.
The cause was the verticle weather stripping on the OUTSIDE rear of the window. The upper portion was folded under the top stripping. Make sure the outer portion of the verticle weather stripping sits outside of the targa weatherstrip - right in the rear corner of the window where the 2 strips meet.
I make it sound like the weather stip is on the window when it's actually on the car body.
