"Paint" Flaking Off Mufflers - Need Ideas
Old Jun 1, 2006 | 01:29 PM
Torch Red 02's Avatar
Torch Red 02
Default "Paint" Flaking Off Mufflers - Need Ideas
I have a 2002 Coupe with 30K miles. It's in outstanding condition, inside and out. Bought it at 18K miles nearly two years ago. The paint or coating on the stock mufflers is flaking off. Looks like it's aluminized or stainless underneath. Any ideas for a DIY fix at home (no lift available) to paint or coat them so they look original (black) again?
Old Jun 1, 2006 | 01:39 PM
Sako's Avatar
Sako
I painted the mufflers of a '96 LT4 using paint made for barbeque grills. I bought a quart can at Home Depot. I used scotch brite pads and alcohol to clean them and then painted. Worked very well. I plan on doing my '02 vert.
Old Jun 1, 2006 | 01:45 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Get some stainless 2 or 4 tip Borlas
Old Jun 1, 2006 | 02:15 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I did the same.
I brushed on some high temp flat black BBQ paint. Works fine.
Old Jun 1, 2006 | 02:20 PM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
I used "rub n buff" I got it from a arts and craft store like Hobby Lobby. I put it on a year or so ago and it is still there. Never burnt off. You can see it on my pipes. Hope this helps.
Old Jun 1, 2006 | 03:46 PM
Oldvetter's Avatar
Oldvetter
Exactly what I did, only I used exhaust paint (flat black), wire brush, and alcohol. This is what the TSB calls for.
Old Jun 1, 2006 | 06:06 PM
rpm462's Avatar
rpm462
My 03 w/32,000 miles is doing the same thing....figure I'll use it as a reason to justify getting some GHL Bullets this fall!!
Old Jun 1, 2006 | 09:09 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Check the 2001 Corvette TSB listing from Chevrolet. They issued one while I had my 2001 Coupe covering the flaking paint on the mufflers. Had it fixed under warranty. The TSB was very specific as to a strip, and repaint process along with a specific paint recommendation. It worked for 2+ years with no additional flaking till I sold the car. It's worth the effort to fix it one time correctly.
Old Jun 2, 2006 | 12:39 PM
Torch Red 02
Thanks! This was just the kind of advice I was looking for.
Old Jun 2, 2006 | 12:46 PM
Corvette1996LT1's Avatar
Corvette1996LT1
Get some sand paper clean it up and get high temp spray paint and tape off the parts you don't want to paint. That will give you that factory look. I would never brush paint them
Old Jun 2, 2006 | 06:21 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
The stock exhaust system should be stainless...i would use the grill high temp paint and repaint them. For my stainless corsas, i used POR 15 manifold gray and painted them for a factory look, of course the tips are bright chrome
Old Jun 2, 2006 | 06:39 PM
jrose7004's Avatar
jrose7004
When I had stock mufflers I would regularly paint them with flat black VHT paint.
Old Jun 2, 2006 | 08:30 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by CHJ In Virginia
Check the 2001 Corvette TSB listing from Chevrolet. They issued one while I had my 2001 Coupe covering the flaking paint on the mufflers. The TSB was very specific as to a strip, and repaint process along with a specific paint recommendation. It worked for 2+ years with no additional flaking till I sold the car.
http://www.corvetteactioncenter.com/....php?qstId=268
Old Jun 5, 2006 | 12:54 PM
Torch Red 02
Thanks again for the great advice. I love this forum!
Old Jun 5, 2006 | 12:57 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I had the same problem with my '02 coupe. Solved it by buying a set if Corsa's.
To "Paint" Flaking Off Mufflers - Need Ideas
