CB Radio Install
Old Jun 1, 2006 | 09:04 PM
George8211's Avatar
George8211
Default CB Radio Install
I've just purchased a Cobra 29 CB and have temporary installed to see how things sounded and where I wanted to mount everything. I saw several setups at the Cruise In... Hopefully someone here can chime in.
1. Since there is no body metal to attach an antenna to... I have to frame mount a fiberglass antenna. I'm getting a very weak signal... and it seems to be intermittant...
Could this be because I still am not grounded properly ?? I did all the required tuning already.
2. I'm also picking up a lot of engine electrical interferance on the radio.
Could this also be a grounding problem ??
Old Jun 2, 2006 | 01:33 AM
rrichar2591's Avatar
rrichar2591
I'm attaching a photo (not very good) of the back of my C5 and it may show you how the CB antenna is mounted on mine. It does neet to be grounded. Mine is mounted on a bracket that I bought from our local Corvette Club. Almost all members in the club uses CBs on our trips and runs to various parts of the state. Let me know if I can help in any way.
Old Jun 2, 2006 | 05:26 AM
George8211's Avatar
George8211
I set mine up like you have in your picture. I mounted the bracket using the stud that the exhaust support uses. I thought the metal bracket... mounted to that stud, which is attached to the frame, would create a good ground.
Do I need to run a ground wire from the stud, to a ground wire in the electrical system ??
I like your bracket & antenna. I have the thick roundish fiberglass antenna and it visually drawers too much attention to itself. What brand is the one you have ?? Also... how far does your radio reach ??
Thanks for the help
Old Jun 2, 2006 | 07:22 AM
Pres712's Avatar
Pres712
Default SWR Bridge
Your problem is not a "ground" per se but what is called a "Standing Wave Ratio". With the Corvette being fiberglass there is not place for the signal to go but straight up from the antenna. CB signals need a "plane" to direct the signal back down the antenna to form a loop. A local CB shop should have an SWR meter. You should have a 1 to 1 ratio. Without a proper metal "ground" affect you probably have about a 25 to 1 ratio. The first time I installed a CB in my '67 I mounted copper screen under the convertible lid and ran a ground from it to the antenna and then to the frame. Somehow you need to get this effect. You will probably have to settle to just getting a good ground to the frame. A good CB will "get out" about 10 miles, you will have to settle for about 2. Sorry but that's the price we pay for a non-metal car.
Old Jun 2, 2006 | 08:02 AM
Vettecaster's Avatar
Vettecaster
Thanks for the info! I loved CB radio in the 70's and would love to get back into it, despite issues with the antenna.
Old Jun 2, 2006 | 08:30 AM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
So you skipped Milan because you were monkeying around with a cb?
Old Jun 2, 2006 | 09:21 AM
George8211's Avatar
George8211
No, I was getting my paperwork together for a property sale that took place Wednesday am.
Getting ready to leave for Northern MN at about noon today... be back in a week. Still trying to work the bugs out the CB setup... I did the famous Ground Bolt Breaking Trick this morning... just bought a tap so I can thread a new hole in the frame.
Old Jun 2, 2006 | 10:08 AM
DRJJ1's Avatar
DRJJ1
Default Don T Tell Me No No No No
CB RADIO? SHEESH,,AM I IN A TIME WARP?
Old Jun 2, 2006 | 11:29 AM
debmwb's Avatar
debmwb
That's only true if the wave-length of the antenna being used requires a ground plane (1/2 wave antennas don't need a ground plane). You still may suffer in range, but if you use a 1/2 wave antenna it will match sufficiently.
Old Jun 2, 2006 | 11:48 AM
George8211's Avatar
George8211
I'm wanting a CB to cover me for my cross country trecks... I'm out the door for a 2,000 mile trip to International Falls MN and back. I'm also driving back & forth to Atlanta from Detroit for work. I expect to do about 18,000 cross country miles this year.
It would be nice to have a little more info on road conditions, traffic, and the ticket hazzard areas Detectors alone don't do the trick any more.... Just ask MowtownPaceCar (see his avatar).
Unfortunately, as stated.. the range is pretty weak... and I'm getting lots of electrical interferance from the car... humm ... noise suppression.
To CB Radio Install
