Glass treatment
Old Jun 2, 2006 | 10:38 AM
UncleRobb's Avatar
UncleRobb
Default Glass treatment
I just treated the windshield with Rain-X and it works great. I wonder if it makes sense to also put it on the side windows and the hatch? Right now I have Rejex on these. Somebody in the forum urged not to put Rain-X on other windows than the windshield and reported that it would be difficult to remove.
Opinions?
Old Jun 2, 2006 | 01:02 PM
mschamberger's Avatar
mschamberger
Opinions?
I've never noticed a difference in my side windows, so I quit using it. But definitely do the back. It's a night and day difference with my hatch.
Old Jun 2, 2006 | 01:06 PM
rws.1's Avatar
rws.1
use Rain-X on all windows on my cars.
Did you previoulsy use REjex on the front windshield?
How does the Rain-X compare to the Rejex?
Old Jun 2, 2006 | 01:12 PM
Albino's Avatar
Albino
Me too.
The water rolls right off, and the wind takes the rest away.
Old Jun 2, 2006 | 02:07 PM
UncleRobb's Avatar
UncleRobb
Yes, I previously used Rejex on all windows. On the windshield, the water was not repelled to the extent Rain-X does it.
In the end, I got some spiderweb-like patterns on the windshield that made it difficult to see in heavy rain with all the water spray generated by other cars, especially in the night. These patterns were only visible when the glass was wet.
Last weekend, I cleaned the windshield with Stoner's Invisible Glass and I tried to remove the residue with coarse stainless steel woll. I might have better used fine steal woll, but anyway, the spiderwebs are now gone. I suspect that these patterns were created by residues of Rejex. However, since I bought the car used and since I regularly treat it with wax in the automatic car wash, I cannot be sure of this.
Old Jun 2, 2006 | 02:19 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Has anyone ever used a clay bar on their windows? If so, what were the results? Would you recommend doing this?
Old Jun 2, 2006 | 02:31 PM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
My old detailer swore by clay bar use on all exterior parts of your car...glass, chrome...even plastic. I tried it and it works. The only down side I have seen is that the clay has to be thrown out earlier. I even do the wheels just before I throw one out.
Old Jun 2, 2006 | 02:33 PM
Frozenfire's Avatar
Frozenfire
Rain-X also makes a windshield washer fluid, but you have to flush out the washer reservoir before you add it.
Old Jun 2, 2006 | 03:04 PM
vettesmith02's Avatar
vettesmith02
I've only put rain-x on front, but you can put it on all windows.
I put enough on that even in heavy downpours on the interstate, I don't use the wipers until I am in illuminated regions at night.
Old Jun 2, 2006 | 03:11 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I never had good luck removing the Rain-X haze from my windows. Now its just RejeX for me.
Old Jun 2, 2006 | 03:16 PM
blown in n.c.'s Avatar
blown in n.c.
Coca cola will remove the haze
Old Jun 2, 2006 | 03:17 PM
Madman51's Avatar
Madman51
Claybar works great on windows. Right now I'm just using Zaino on the windows, but Rainx sounds like it's worth a shot
Old Jun 2, 2006 | 03:23 PM
MattB's Avatar
MattB
I don’t know about using that, I put some in my reservoir and it was fine for a while. Then all of a sudden the washers stopped working. I pulled the lines apart and found a lot of a gummy waxy substance was all through the lines. It clogged the outlets as well. It took me several cleanings to get rid of it. And it was a B*#@! getting the stuff off of my windshield and wipers, it would look like a insect hit on the windshield but was like getting off a greasy crayon mark, but more stubborn.
Using the rainx washer solution was the only thing that I did different, and did not mix anything with it. I was either very low or out of solution when I added it, if the remaining fluid caused a reaction I would have expected it sooner.
So, use with caution, it could be a pain in the backside to clean up, but nothing permanent.
Old Jun 2, 2006 | 04:38 PM
rwsr50's Avatar
rwsr50
Opinions?
That was me. I would STRONGLY advise against using Rain-X anywhere due to my personal experience with it. I see others have posted to the contrary though. I can only speak from my experience however. And I tried Coca-cola to remove it. Didn't work for me.
Rain-X seems like the greatest thing since Vettes...at FIRST. The problem comes after it's been on a while and starts to streak and blinds you when on-coming lights hit it.
Good luck with whichever way you decide to go.
Without searching back, I think Evil Twin reported similar experience to mine, and his reputation on here is without repute. (If it wasn't you Bill, my apologies for putting words in your mouth, but somebody else was in agreement with my assessment of Rain-X.)
Old Jun 2, 2006 | 05:26 PM
Lectron Blu's Avatar
Lectron Blu
Try rubbing alchohol. It seems to remove wax and grease easily. Another trick is to use a product called Bon Ami Polishing Cleanser or any product that is for use on ceramic cooktops.
Old Jun 2, 2006 | 07:21 PM
rwsr50's Avatar
rwsr50
Tried Bon Ami too. That was after I called Rain-X and asked them what I could use to remove it. They weren't being very cooperative, and I was about to threaten to sue if I was in an accident because of being blinded by the glare, when they suggested Bon Ami. The only thing that finally got it off was the wipers and only after a long period of time, like 2 or 3 years. Never did get it off the part of the windshield the wipers didn't sweep.
For anybody who's thinking of trying Rain-X, I would recommend trying it on some car other than your prized Vette first...preferrably one you are planning to get rid of in the near future, ha, ha.
Old Jun 2, 2006 | 07:26 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
I'll try the clay bar this weekend! I hope I will notice a big difference!
To Glass treatment
Old Jun 2, 2006 | 07:40 PM
rwsr50's Avatar
rwsr50
I got some of that DP High Performance Glass Cleaner from the AutoGeek a while back and haven't tried it yet. It's supposed to be raining tomorrow, so maybe I'll finally give it a try. That and clay barring the glass.
I have water spots etched into my glass from minerals in the water. It was like that when I bought it. Hopefully I can get rid of them, but I have my doubts. I already took it to an auto glass place to have it looked at and they tried scraping with a razor blade to no avail. I'll let you all know what happens.
Old Jun 2, 2006 | 07:44 PM
rwsr50's Avatar
rwsr50
Hmmm, there I go with my crazy ideas again. If Rain-X sticks that good to glass and is impossible to get off, and repels water like it does, I wonder if it would work on paint? Might be a more durable replacement for wax.
Wonder if anybody ever tried it? If it sticks to paint like it does to glass, you'd never have to wax your car again!
Old Jun 2, 2006 | 08:02 PM
Hammie's Avatar
Hammie
I have been using Rain-X for about 7 years now, and I don't know where in the hell people are having these problems. I use ti on every window. Squirt some onto a washcloth, and apply it onto window. Let it dry, then repeat for a second coat. To remove the excess haze, take a damp towel and wipe it away. Clear as ever.
Just make sure you're applying to a perfectly clean window. No problems with mine. If I ever had excessive haze, one washing got rid of it.
