Am I Missing A Diff Cover Bolt ???
Old Jun 4, 2006 | 12:57 PM
MikeGrz's Avatar
MikeGrz
Default Am I Missing A Diff Cover Bolt ???
My '04 auto had the left differential cover leak repaired twice at "dealer A" and lastly at "dealer B". I again found fluid on the floor, put the car on ramps, and wiped up the left side. There isn't a bolt in the top rear cover spot. The manual is not clear enough fto indicate if that spot is a locating dowel or a broken off bolt. Thanks for your help
Old Jun 6, 2006 | 07:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Mine is the same. I thought the same thing when I first saw that. No leaks.
HTH,
Robert
Old Jan 22, 2011 | 06:25 AM
les-mon's Avatar
les-mon
1st Gear
Default bolt missing
Just check and make sure you havnt got a dana 36 cover on a dana 44 as the 36 has a extra bolt up top in the middle
Old Jan 22, 2011 | 10:16 PM
C5FORFUN2's Avatar
C5FORFUN2
No Dana's in C5s
To Am I Missing A Diff Cover Bolt ???
