Squeeks In Engine Bay
Old Jun 4, 2006 | 08:19 PM
Railfan's Avatar
Railfan
Default Squeeks In Engine Bay
I have noticed occasional squeeks coming from the engine bay, especially when it is really hot outside. Today it is only 70 outside and there are no squeeks coming from under the hood. Would this maybe be a need for a new belt? Or could it be something else? Would it be a good idea to get a new belt anyway, just in case?
Don't want to spend any money I don't need to, but would rather be safe than sorry.
Please give me your opinions.
Thanks.
Railfan
Old Jun 4, 2006 | 08:28 PM
Railfan's Avatar
Railfan
Oh yes. The vette is a 99 auto with 21000 miles on her.
Old Jun 4, 2006 | 11:23 PM
Sammy_C5's Avatar
Sammy_C5
Old Jun 4, 2006 | 11:25 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
could be the tensioner going bad or worse yet in my case the bushing between the bottom pulley and the balancer was seperating......lemme see if I can find that thread....
Old Jun 4, 2006 | 11:27 PM
pewter99's Avatar
pewter99
here we go....check this
http://forums.corvetteforum.com/show...ghlight=squeek
Old Jun 4, 2006 | 11:34 PM
DngrZne's Avatar
DngrZne
Also, I think I've read that rust on the pulleys can cause some noise as well.
Old Jun 4, 2006 | 11:38 PM
pewter99's Avatar
pewter99
well your other option is to buy a mechanics stethoscope and try that next time it starts squeeking...they can be had for about $20...
Old Jun 4, 2006 | 11:43 PM
GrayC5's Avatar
GrayC5
As pewter99 mentioned, check tensioners along with your idler pulleys. There is a tensioner and an idler pulley on both the main drive and AC belt.
Also, see the following service bulletin:
1997-1999: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)
Good luck with the fix.
Old Jun 4, 2006 | 11:53 PM
pewter99's Avatar
pewter99
yeah I thought it was my idler pulley although it was fairly new after the SC install but the squeek was intermittent and I could trace it...some days it didnt squeek at all then one day I noticed the belt was shredding
Old Jun 5, 2006 | 07:53 AM
Railfan's Avatar
Railfan
Thanks for the info. The belt has not squeeked for the past three days or more and when I took it in, I told the techs that fact. They told me to wait for the squeeks to start again and then to just bring it in so they could hear it. Hope I don't have any problems jump up and bite me in the @ss because of this holding off.
Will take a good look in the engine bay and see if I can find any evidence of what you all were talking about. Thanks again.
Railfan
(5 minutes later)
Well, I checked out the engine bay and could see no clue to a bad bushing, nor could I see any rust. But then again, I'm not a mechanic and really don't know what and where to look. Belt seems fine; no frays. As for the tensioners, how can you tell? Is there anything I can do as for lubricating, or whatever, to eliminate any other possible causes?
Thanks again.
Railfan
Old Jun 6, 2006 | 01:46 AM
GrayC5's Avatar
GrayC5
Originally Posted by Railfan
...(snip)...Is there anything I can do as for lubricating, or whatever, to eliminate any other possible causes?
Thanks again.
Railfan
No lubricants. Get them on your belts and you may have even more problems. Best to do as your tech recommended and wait until the squeaks start again and you can determine where they're coming from. Then, you will know what needs to be fixed.
Old Jun 6, 2006 | 06:17 AM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Old Jun 6, 2006 | 07:43 AM
Railfan's Avatar
Railfan
OK, thanks.
As a side, I found an independant shop that has a couple of technicians that are experienced/trained on corvettes. In fact, when I stopped in to check the place out, they had two C3s sitting there being worked on. After talking to them, they seemed very competent and friendly. Have a good feeling about this place, hope it works out.
Railfan
Old Jun 6, 2006 | 07:51 AM
ROADAPPLE's Avatar
ROADAPPLE
Back in the 60's and 70's we used to call small block Chevys "Mouse Motors" as opposed to the "Rat" motor big block, maybe there was something to that.
Old Jun 6, 2006 | 05:01 PM
Railfan's Avatar
Railfan
My family, when I was growing up in those times, was always buying MOPAR. So I can't recall anything like that. If that was indeed the case about Chevy engines, what was the likely cause for the squeeks?
To Squeeks In Engine Bay
