St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
sill protectors
I would like to order a set of sill protectors but their are so many that mid america carries i think i would like the clear ones.Does anyone have any suggestions on which to order and do they ruin anything when you put these over the sill.Thank you charlene
I had some clear ones years ago....they do OK...I didnt attach them I let them just sit there..they do allow water to get beneath them and dirt....didnt really cause any paint damage and they eventually cracked at the bend between the bottom piece and where they came up toward the sill....IMO...save your $$$
I have the clear plastic sill protectors with Corvette in black letters, from Mid America. Have used them for about 7 months. I waxed the sill twice before I put them on. Water does get under them when you wash the car or it rains hard. Not a protector problem, rather a Corvette weatherstrip problem. I take them off before the wash and replace after drying. A gripper on the carpet side holds them in place. If you exercise a little care when removing and replacing them I don't think they will scratch the sill. I don't have any scratches yet. I do believe they have saved me from a lot of scuff marks on the sill.
Wordy but factual...cheers
I'm actually on my second set because the first set got so scuffed up they started looking a little ratty. Better and easier to replace a set of protectors than have the sill repainted because it was scuffed up!
I've go the same set up and they have been on for years-no problems.
I have a clear set that came with the car. The only problem I've found is water getting under them as others have said. For this reason I would suggest you use clear if you changed your mind and decided to try them.
