SOS: MN6 problem
Old Jun 5, 2006 | 06:05 PM
Intimidator3's Avatar
Intimidator3
Default SOS: MN6 problem
Currently have about 28K original miles on my 2002 coupe, and today I started the car I was unable to get the car into gear at ALL. Also the clutch would stick half way down and not release. I have a call into the dealer for service. Has anyone ever experience this problem?
Old Jun 5, 2006 | 06:09 PM
NSTG8R's Avatar
NSTG8R
my first thoughts are the master cylinder is fooked .. but thats just my guess.
Old Jun 5, 2006 | 06:14 PM
astrolite's Avatar
astrolite
Hydraulic system for the clutch.
Slave cylinder or master...
Do you see a puddle of fluid under your car? It might be that air got in and they need be bled - or one of the cylinders has a leak.
Happend to my car and I just went ahead and got a whole new clutch put in while they had it apart. Not sure if it'd be worth it @ 28k miles though.
Old Jun 5, 2006 | 06:26 PM
Intimidator3
I have not notice any puddles under the car, but the previous time I started the car, the same thing happen. Once I got it warmed up and after about 6 painful mile the car was fine. It would shift fine.
Old Jun 5, 2006 | 06:27 PM
NSTG8R's Avatar
NSTG8R
so is it a hard shifting or a hard clutch press?
Old Jun 5, 2006 | 06:38 PM
Intimidator3
More like no shifting. And the clutch stayed half way down. This morning the car would not go into gear. I was not about to play around with it. Have a call into the dealer. First open spot is next Tuesday.
Old Jun 5, 2006 | 06:41 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
is it warrantied still? If so I would just wait for them.
Old Jun 5, 2006 | 06:47 PM
Intimidator3
I have a GM extended warranty, but the only thing that I have used it for is a coster
Old Jun 5, 2006 | 06:56 PM
NSTG8R's Avatar
NSTG8R
well time to remove your drink from on top of it and put it to good use.
Old Jun 5, 2006 | 07:12 PM
MisterC's Avatar
MisterC
This is beginning to be a common problem. You most likely will need to replace both the slave and master clutch cylinders. While your in there, a new clutch system will save you the headache of having to go back in for that. An opinion based on my own experience.
To SOS: MN6 problem
