Blackwing
Old Jun 5, 2006 | 06:40 PM
istsme98's Avatar
istsme98
Default Blackwing
Just finished installing the Blackwing, pretty easy install except that the coupler wont sit down as far as it needs too. Will work on it later.
Old Jun 5, 2006 | 06:44 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I got one comin' and I can't wait!
Old Jun 5, 2006 | 06:46 PM
Z28TOZO6's Avatar
Z28TOZO6
Bill Curlee just put mine in a couple of weeks ago. Thanks again Bill!
Old Jun 5, 2006 | 07:45 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
don't waste too much time. Mine doesn't go all the way down either. Sits up about 1/2 "
Old Jun 5, 2006 | 07:55 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I do foresee this as being a problem with mine too.
Old Jun 5, 2006 | 08:32 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Mine doesn't either.
Old Jun 5, 2006 | 09:10 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Are you using an aftermarket coupler? I have one of those red ones, and I had to trim about an 1/8" off the coupler to get the airbridge to sit down on the pegs. It works just fine now.
Old Jun 5, 2006 | 09:41 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Mine fit perfectly, took a little finessing but it went on smooth, nice seat of the pants improvement
Old Jun 5, 2006 | 10:02 PM
istsme98's Avatar
istsme98
I am using the stock one .
Old Jun 5, 2006 | 11:30 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Buy the bigger air bridge and you won't even think about this again.
Old Jun 6, 2006 | 12:02 AM
jrose7004's Avatar
jrose7004
Great basic mod!
Old Jun 6, 2006 | 12:20 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Yes with a little finessing it will fit like it was from the factory.
Old Jun 6, 2006 | 12:51 AM
StoplightWarrior's Avatar
StoplightWarrior
Ok, so wtf?! The blackwing was the only mod my c5 had when I bought it. I was installing my throttle body bypass and noticed that my IAT sensor was unplugged. In this pic you posted I see where it's supposed to go, but my blackwing flat out does NOT have a spot for me to plug mine in...do I need to drill one??
Here is a pic of what i'm talking about:
My IAT sensor just hangs loose in my engine compartment.
Old Jun 6, 2006 | 07:15 AM
Mike98SilVert
You must have an aftermarket airbridge. You can either drill the proper size hole in the airbrige and make sure it seals completely with the sensor in by using a hollow rubber grommet or install a stock airbridge with the provision in place.
The MAF sensor measures airflow into the engine and proportions fuel to the engine based on a preset air fuel ratio for economy. The MAF sensor does not read the airflows above the cruise and part throttle operation. The computer must calculate fuel from a factory table based on RPM and calculated load.
Old Jun 6, 2006 | 07:57 AM
C5XTASY's Avatar
C5XTASY
Remove the flow gauge device from the top of the Blackwing and plug in the IAT sensor. 1997-2000 C5's had their sensors mounted in the powerbridge, as your picture shows. 2001-2004 C5's incorporated the IAT sensor as part of the MAF. The Blackwing is a better place to put it, anyway, as there's a lot less heat-soaking there, so when you hot-start the car, your timing rollback, because of heat sensing, will be a lot shorter duration. It's what Lingenfelter does when they mod a motor.
Ed
Old Jun 6, 2006 | 08:10 AM
Allzwell's Avatar
Allzwell
St. Jude Donor '03 thru '20
Ed
Old Jun 6, 2006 | 12:23 PM
Good choice. Blackwing is a very good air intake.
Old Jun 7, 2006 | 09:10 AM
dankhts's Avatar
dankhts
Mine's the same, but about 1/4".....
Old Jun 7, 2006 | 10:28 AM
DADEO1's Avatar
DADEO1
Default Mounts flat on bushings.
Mine did that too until I took it loose again and cleaned my radiator.
Push up on the shroud while its unbolted ( two bolts on each side of shroud ) and snap the support bushing back in place. Use some lube
( window cleaner works OK ) on the rubber bushing.
Mine has stayed in place since then.
Hope that helps.
To Blackwing
