[Z06] Low oil level warning???
Old Jun 6, 2006 | 12:21 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Low oil level warning???
The low oil level warning message appeared on my 02 Z approximately 2500 miles after my previous oil change. This was my first oil change since I bought the car(I changed the oil immediately). I checked the dipstick and oil needed to be added. I added a quart and the warning message went away. I spoke with the shop foreman at the local Chevy dealer, and he said this is completely normal with these engines and I shouldn't worry about it. What do you all think?
FWIW, my car was built in February of 02. What build "stage" would this be considered for 02's?
Old Jun 6, 2006 | 12:26 AM
pb24dagrk's Avatar
pb24dagrk
:beatingadeadhorse:
Old Jun 6, 2006 | 12:28 AM
pb24dagrk's Avatar
pb24dagrk
http://forums.corvetteforum.com/show...6&postcount=10
Old Jun 6, 2006 | 01:15 AM
03 Z-oh-6's Avatar
03 Z-oh-6
My car is not an 01, hence why I'm a bit concerned.
Old Jun 6, 2006 | 07:55 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
I would not worry about it, my 2000 FRC used a little bit of oil. It is normal.
Old Jun 6, 2006 | 09:46 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
How much oil did you put in it after the oil change? Some people do not fill it up all the way usually 7 quarts for the Z will put you at the full mark on the stick. If you used 6.5 you started out a half short and then used up a half which is not a big deal. Start out full next time and set one of your trip meters to keep track of your miles when you have to add some next time. HTH, Don
Old Jun 6, 2006 | 08:31 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Chevy did the oil change, so I'm assuming they put in the proper amount. 2,500 miles later I got the low oil warning, so I put in a quart and the warning went away. I don't know what to think?
Old Jun 6, 2006 | 09:03 PM
Z11409's Avatar
Z11409
Oil is cheap--drive it and have fun
Old Jun 6, 2006 | 09:04 PM
briann510's Avatar
briann510
Most people I know put in 6.5 qts to get it right in between add and full marks. I always put in 6.5 qts and just changed it at 25% remaining on the DIC (4800 miles on the oil), and it hadnt used any oil at all when I checked it before draining.
Of course I made one helluva mess when I tripped carrying the drain pan over to the dump barrel and it all went on a newly poured driveway. It all cleaned up nicely once i dumped about 2 gallons of gasoline on it though.
Old Jun 6, 2006 | 10:47 PM
03 Z-oh-6's Avatar
03 Z-oh-6
True. I'll just make sure I always have enough oil and enjoy this beast!
Old Jun 7, 2006 | 09:46 AM
dwjz06's Avatar
dwjz06
Dogface
Never assume Chevy mechanics know what they are doing! Ever get a new car from the dealer with most of the fluids low? I have had two. Just because they make the car does not mean they know all of the details about each one. And most will not take the time to look it up! Do your own changes, and you will find it takes 7 to get to the full mark on the stick. Can't go wrong there. And if you race it add another half to whole quart. Enjoy the car! Don
Old Jun 7, 2006 | 09:51 AM
Twil1ght's Avatar
Twil1ght
That's your first and second mistake.
Old Jun 7, 2006 | 10:11 AM
Bret01Z06's Avatar
Bret01Z06
Old Jun 7, 2006 | 11:33 AM
bud miller's Avatar
bud miller
pretty normal for an 01-mine gets about 2k-2500/qt-i drive till i get the msg in the DIC-add a qt and off i go....works like clockwork..i trust the msg in the DIC, and i have 35k on my 01,no problems...
here is a tip....just change your fuel filter often and clean out the throttle body area at the front every yr and it will idle great and run like new....
Old Jun 7, 2006 | 08:34 PM
03 Z-oh-6's Avatar
03 Z-oh-6
The manual says 6.5, some people say 7 quarts. Which is correct?
Old Jun 7, 2006 | 08:49 PM
Andy64's Avatar
Andy64
I also have my dealer do the changes because I really dont have much level property at my home to work properly. My guess is engine capacity is 6.5 without accounting for the oil filter and the extra 1/2 quart covers the new filter.
Old Jun 9, 2006 | 10:11 AM
dwjz06's Avatar
dwjz06
Dogface
6.5 is correct for manual. It takes 7 to reach the full mark on the dip stick. I have always used 7 and it stays full. I have 47K on my car now.
Old Jun 9, 2006 | 10:46 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I always use 7 quarts... fill your car until it's at the full mark, notate the miles and keep track of it from there.
The valley seal in the PCV system can go bad and the car will use oil. This is the source of excessive consumption on '02+ cars.
It's a fairly easy fix/replacement but you have to pull the intake manifold.
My '01 used a quart every 900 miles... then i had the valley seal replaced and it used a quart every 1500ish miles. Then I had it re-ringed and switched to 5w40 Amsoil and it doesn't use any oil between 6000 mile changes.
Old Jun 9, 2006 | 04:43 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I put 7 in mine the last time I changed the oil and it was up to the full mark on the dip stick.
To Low oil level warning???
