5.3 Heads
Old Jun 6, 2006 | 10:19 PM
freemanjc's Avatar
freemanjc
Default 5.3 Heads
Anbody running 5.3 heads vice 5.7. I was Just curious if they will raise the compression of the c5 if milled to .010
R,
Free
Old Jun 7, 2006 | 12:00 PM
freemanjc's Avatar
freemanjc
All this knowledge in here and no one could help! I sure miss EVIL TWIN, he was "friendely" and very relaible.
Old Jun 7, 2006 | 12:05 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have a buddy running a set of 5.3L heads, not sure if they are milled, but I don't think that the compression will be an issue. I recommend posting this question on LS1TECH or in the TECH section. You will find the really hardcore folks there and they will be able to give you a better answer to your question.
Micah
Old Jun 7, 2006 | 12:25 PM
fdxpilot's Avatar
fdxpilot
R,
Free
They will raise the compression, even without milling. IIRC, the chambers are 59cc. They have smaller valves (exhaust only, I think) and the ports will need work to equal LS1 flow. A set off worked over 5.3L heads might help, but stock, no.
Old Jun 7, 2006 | 01:02 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
2 things...
number one... you posted this in the wrong section. try posting in "TECH" as you might get a little more help over there.
2nd thing.... as much as i love this forum... i find technical questions are best answered over at ls1tech.com. lot more "technical" knowledge over there.
To 5.3 Heads
