OEM C6 wheels on a C5?
Old Jun 8, 2006 | 09:54 PM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Default OEM C6 wheels on a C5?
I know it's been asked but I've searched for over an hour and cant find the answer.
Do stock C6 wheels bolt on a stock '00 C5 or do you need a spacer?
Old Jun 8, 2006 | 09:58 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The answer is yes and no. The fronts will fit fine, but the rears will not. The rears need a spacer...
http://forums.corvetteforum.com/show...tock+c6+wheels
Peace
Willfulone
__________________
..................Click for
Old Jun 8, 2006 | 09:59 PM
greg_nate's Avatar
greg_nate
You'll need a spacer. The polished aluminum C6 wheels require more of a spacer. The chrome C6 wheels require less. Minimum 1/2 on the aluminum ones. 1/4 will work fine on the Chromies.
I've had both on my car. Originally had the polished aluminum C6 wheels as replacements when my polished Y2Ks were stolen. I got the polished C6 wheels thinking they'd be shiny like my Y2Ks. No Dice. In fact, they looked bad. They weren't shiny at all - damn near gunmetal grey looking.
Had to space the heck out of the polished aluminum wheels to get them to work. I couldn't stand the look of them though, so had them replaced with a set of chromies. I was surprised that they were a different offset, requiring less of a spacer. They are the perfect fit actually - coming exactly even with the fender well. They also clean up *MUCH* easier than the polished aluminums. I am very pleased with my setup.
Old Jun 8, 2006 | 10:04 PM
burbleflyer
St. Jude Donor '08
Thanks so much for the info. My search was getting frustrating!
Does anyone make a spacer?
Old Jun 8, 2006 | 11:27 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I just put C6 wheels on my wife's C4 (which is close to the C5 mounting). It took a 1 1/8" rear spacer. Looks good though.
Old Jun 9, 2006 | 12:31 AM
crvtble's Avatar
crvtble
Don't confuse the word "spacer" for adapter. If you want to mount the c6 wheels to where they fit the wheel well nicely...Don't fool with the spacers. You want a 1" thick aluminum adapter. Ebay lists a whole bunch of people that sell the adapters for c5's.
Old Jun 9, 2006 | 12:32 AM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
discount tire should be able to get them for you
frank
Old Jun 9, 2006 | 06:35 AM
torchvette10's Avatar
torchvette10
I prefer the C6 ZO6 wheels on the C5!!!
Old Jun 14, 2006 | 09:59 AM
Brian Spaulding's Avatar
Brian Spaulding
4th Gear
How did the spacer affect the wheel bolting to the studs? Did you have to change out the studs?
To OEM C6 wheels on a C5?
