Alignment or balance?
Old Jun 9, 2006 | 09:51 PM
LoneStarFRC's Avatar
LoneStarFRC
Hunter 9700
Old Jun 9, 2006 | 11:31 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Old Jun 10, 2006 | 12:41 AM
Cole's Avatar
Cole
Originally Posted by Railfan
I
My question: Is a continuous vibration due to misalignment, or wheels out of balance?
Thanks.
Railfan
Vibration is almost always balance and performance tires can be a bit tricky. Take the car back and request a redo. They will not be surprised.
When I switched to non-runflats, I noticed tire wobble - something I hadn't felt in years. I adjusted tire pressures and solved that problem pretty easily. I now run 32-33 pound all around versus 30 with the run flats. The cars are excellent handling machines and sensitive to minor changes.
Old Jun 10, 2006 | 01:07 AM
GrayC5's Avatar
GrayC5
Originally Posted by blacksedan87
I agree with the others - vibration=balancing issue.
Is the shop performing a road force balance? This is important because the newer Hunter machines (there are others too - but Hunter was the original and the best IMO) checks for run out of the rim besides balancing. Point is if the wheel is slightly heavy on one side due to irregularities in the casting or forging process and the tire is also a little heavy from the molding process - the run out will verify that. A good tire tech will recognize the condition and break the beads on the tire - and turn the tire on the rim.
My suggestion is to specifically ask for a road force balance.
Good info and advice from Randy.
Old Jun 10, 2006 | 01:11 AM
GrayC5's Avatar
GrayC5
Originally Posted by DJ_Critterus
Get the wheels balanced and have the tire installer check for run out inthe tire.
BlackSedan, what shops do you know of that do this road force balance?
You can also click on the Locate a GSP9700 tab at the top right at the following link to find other shops in your are:
Hunter's GSP9700
Old Jun 10, 2006 | 08:24 AM
Railfan's Avatar
Railfan
Hunter's GSP9700
Thanks. Did that and found 5 locations in my town; one of which is where I got my new tires. Hoping they have someone there who knows what they are doing.
Railfan
Old Jun 21, 2006 | 11:40 AM
Railfan's Avatar
Railfan
Well, I finally was able to get back to have the tires rebalanced. The place where I purchased the tires have a Hunter 9700, but it is broke and they can't do a road force balance. So I had them do a regular balance.
Results: One rear tire was off by a quarter ounce and the other rear tire was off by a half ounce. The fronts were fine. Don't know if that would be enough to cause all the vibration I had been feeling (in the seat of my pants and in the door handle mostly), but on the way home from the garage I was able to get up to 55 mph and noted that most of the vibration (65%) was gone.
Hopefully when the garage gets its new 9700, I can go back in and get a road force balance.
Question? Would it be worth my time and money to now get the car realigned (just done four weeks ago)?
Railfan
Old Jun 21, 2006 | 11:59 AM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
I followed this advice from Sedan and it took a lot of the "kidney shake" out of the rear of my vette. There's still some vibration but I attribute it to thousands of miles of driving with improper balancing.
Old Jun 21, 2006 | 12:39 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Railfan
I doubt if the alignment has changed in four weeks. You would be better off finding someone that has a working Hunter 9700 and having the four wheels/tires rebalanced. I maintain that this will have the greatest effect on your problem. Alignment is important for tire wear and handling, but does little or nothing to cure vibration.
Old Jun 21, 2006 | 03:42 PM
Railfan's Avatar
Railfan
Thanks. The shop said that they are expecting their new 9700 any day now. I am going to wait a couple weeks for them, since I bought my tires from them and will get the rebalancing done for free (sort of anyway). If they don't get the new one by then, I might have to go down the street to their competitor and have them road force balance the tires.
Again, thanks for all the great replies. This forum ROCKS!!!
Railfan
