Caliper Question
Old Jun 9, 2006 | 11:01 PM
Milkman2's Avatar
Milkman2
St. Jude Donor '06-'07
Default Caliper Question
I am getting my Calipers power coated tomorrow so, I have them all out and stripped, clean and ready to go. My question is can I reuse the rubber and seal that I removed?
I am planning on purchasing re-build kit for each with comes with rubber on the piston and the rubber seal is this necessary? If you have done this please advice.
Old Jun 9, 2006 | 11:05 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Depends how old are the calipers and how many HPDE on them. Since you are already in there, I would replace the seals.
Old Jun 9, 2006 | 11:15 PM
Milkman2's Avatar
Milkman2
Thanks, point will taken. They have about 15K miles on them I hope I can get the kits tomorrow.
thanks for your quick reply.
Old Jun 9, 2006 | 11:22 PM
5.0 RACER's Avatar
5.0 RACER
Powdercoating will subject your calipers to a baking at 400 degrees to cure the powder coating. ANYTHING that is not metal should be replaced.
Old Jun 10, 2006 | 12:43 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When I had my calipers powder coated recently, I bought the caliper rebuild kits from my local dealer. IMO - it's the right way to do it. Then make sure you drain and clean out the brakes lines and resevoir and refill with either DOT3 or DOT4 brake fluid.
Old Jun 10, 2006 | 09:22 AM
Milkman2's Avatar
Milkman2
I am all for doing it the right way.
To Caliper Question
