Hoodliner question
Any ideas on how to make it look "new" again?
You need to be careful with the liner however, maybe use a soft rag on the hood liner to work the cleaner in a little before rinsing, but do not use a brush as the black liner will rip pretty easily.
jeff
As much as I would love to paint you a new liner AFTER you use a brush and water on this...
DO NOT use a brush, rag or water or any other solution on your liner!
There is a sponge between the layers, and it will FUZZ up, real pretty like!
These puppies are very fragile....Take the liner off the car.. Cover up your logo with masking tape and newspaper.. Be VERY CAREFUL taking off the masking tape...
Get a can of black Bar-B-Que Grill high temp paint.. Stand the liner up. Move back about 14" and lightly MIST the liner back and forth in light sprays... Do not concentrate on a particular spot..just evenly mist your liner..
This should work.....
Check out your coolent cover. It has a pin hole on the lid. I have heard some put a thin sponge in the lid..
Good luck and let us know the outcome...
Paula
Thank you! Happy that it worked for you!
