2000 Corvette Coupe/automatic 30,000 miles
Old Jun 11, 2006 | 10:24 AM
Jim Covington's Avatar
Jim Covington
1st Gear
Default 2000 Corvette left rear rattle noise
As a new poster, my 2000 Corvettte Coupe with automatic trans. makes an exhaust rattle sound(as if the muffler is vibrating against the left rear floor pan) on cold start up when backing up and most of the time at 5 mph when coming to a stop. I have replaced the mufflers, hangers, converters, bottom side idler pulley bearing. Also get a vibration in the steering wheel at idle particularly with the AC on . Two GM dealerships have been unable to find the problem..anyone else diagnosed this problem? thanks
Old Jun 11, 2006 | 10:41 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Welcome to the Forum
The are many sections here on the Forum, one is a Tech section, you may want to try there for an answer to your issues Good luck.
http://forums.corvetteforum.com/forumdisplay.php?f=1
Old Jun 11, 2006 | 02:06 PM
filmelf's Avatar
filmelf
St. Jude Donor '06-'08
Old Jun 11, 2006 | 02:31 PM
GrayC5's Avatar
GrayC5
Welcome to the Forum! :
Could either of the following possibly be the problem:
1997-1998: Service Bulletin: Exhaust Muffler Insulator Rumble Noise
2002 - 2004: Service Bulletin: Jingling Noise On Deceleration or Coast Down (Section and Replace Intermediate Exhaust)
Good luck with the fix.
To 2000 Corvette Coupe/automatic 30,000 miles
