speed bump rash
Old Jun 11, 2006 | 02:16 PM
MTLNY's Avatar
MTLNY
Default speed bump rash
I just purchased an 01 z06....It came with a 4"x2" rash under the rocker panel. It's not noticable unless you look up at it...It is not cracked....just shows the white of the glass..how can this be repaired, is it expensive, is it a big deal or is it easy?.....what can or should be done?
Old Jun 11, 2006 | 05:18 PM
MTLNY's Avatar
MTLNY
anyone?
Old Jun 11, 2006 | 05:23 PM
rww72's Avatar
rww72
If it's not cracked and you can't see it, live with it!
Old Jun 11, 2006 | 07:10 PM
MTLNY's Avatar
MTLNY
Thanks ....not the answer i was looking for
Old Jun 11, 2006 | 08:17 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
If it is under the car and can't be seen without getting under it I would just leave it.
But if it bothers you and you want to get it fixed I'm sure any body shop will be glad to paint it for you.
Old Jun 11, 2006 | 08:21 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
You sound kind of particular and are someone who will want the job done right. That will entail the entire rocker panel getting resprayed. They're going to fill in the scratches with plastic filler, sand smooth, apply primer and paint. It won't be cheap. Good luck.
Old Jun 11, 2006 | 08:44 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
If the rest of the car is pristine then you probably want to fix it. You're probably looking at $500...
Bob
To speed bump rash
