Interior color question
Old Jun 12, 2006 | 07:01 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Interior color question
I have an area that is staring to peel on the radio bezel. The layer underneath has more gloss to it and is very ugly.
What, if any, touch up/home depot/lowes paint best matches the interior black for a touch up.
Old Jun 12, 2006 | 07:10 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Forget Home Depot or Lowes. Find an automotive paint supplier in your area and they will have the factory correct aerosol paint that will perfectly match your interior. I did this for a previous vehicle. The product I was sold is called SEM Coat. It's a flexible paint specifically for automotive interiors. Plastic, vinyl and carpet. Excellent stuff. Good luck.
Old Jun 12, 2006 | 07:17 PM
screw991le's Avatar
screw991le
Thanks, I will try to located a paint supply shop.
Old Jun 12, 2006 | 07:39 PM
JMc's Avatar
JMc
It shouldn't be too tough. Find out where your local body shops and auto painters are buying their supplies and go there yourself. That's what I did. You may have to order what you need online, but the main thing is to use a product that is formulated specifically for the intended use for the best results.
Old Jun 12, 2006 | 07:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I think Corvette America sells the black paint however it will probably not hold up.
Mine was peeling and I ended up buying new parts from Vette Essentials.
I think C5kidd sands, repaints and puts clear on to stop the peeling.
It's very hot in the console area due to the exhaust, you'll probably see wear marks on your center console where your right knee rubs against it.
The Black you are seeing is the same color that the rest of the interior plastic pieces are, except GM coated them so that they would match the flat black leather vinyl of the dash.
Good Luck
To Interior color question
