C5 Headlamp motor problems
Old Jun 13, 2006 | 07:38 PM
AZRedRover's Avatar
AZRedRover
3rd Gear
Default C5 Headlamp motor problems
A month ago my passenger side headlamp on my 2001 C5 started to not open intermittently. Yesterday the driver side wouldn't open and the passenger side would, even at the mid-stalk position. When it closed it gave a grinding plastic gear sound. Is it possible that both motors are bad at the same time? Or is there perhaps a relay type device between the stalk and the headlamps? If both are indeed bad, what it the best and most cost effective resolution?
AZRedRover
Old Jun 13, 2006 | 07:58 PM
diyguy's Avatar
diyguy
This is an easy fix. Do a search on "Rodney Dickman", then get and replace the gears and you are set for life!
Old Jun 13, 2006 | 09:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
AZRedRover
I assume that you read the first page on the sticky located at the top of C5 Gen, right?
http://forums.corvetteforum.com/showthread.php?t=984927
If you want some help (I've done it on mine) let me know - I just live up the road from you.......
Old Jun 13, 2006 | 10:16 PM
RobertEarl's Avatar
RobertEarl
If this is the first time it has happened, you have just stripped one side of the plastic gear. Instead of taking it all apart, you can unbolt the arm at the moter an then turn the **** on the end of the motor untill the shaft has rotated 180 degrees. Then bolt the arm back on. You have now moved the bad spot on the gear to the other side where it will not be used and you will be good to go for awhile and did not have to break the motor apart. If it happens again, you are stuck and will have to break the motor apart and replace the gear. This is a no cost fix that will work the first time you have this problem.
Old Jun 13, 2006 | 10:48 PM
LoneStarFRC's Avatar
LoneStarFRC
www.rodneydickman.com
To C5 Headlamp motor problems
