From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Sounds like the wiper motor shorted out. I had this happen on my '98 and it was due to the little rubber things getting clogged with trash and not allowing the water to drain as quickly as it should, therefore allowing water to rise up over the wiper motor during hard downpours. This will cause premature damage to the wiper motor if if sits in water.
I have the same problem on my 97 Chevy pickup. A friend who was a GM Tech tells me it was a common problem (in pickups at least) - a broken solder connection in the park circuit of the circuit board in the wiper motor.
Solution: Find & resolder the bad connection or replace the circuit board. Cost of circuit board for the pickup is about $50. He's going to resolder mine "when he gets time".
I'm not sure if this is the same issue for C5's, but it certainly seems possible - unless C5's have a unique wiper system?? Would be a good place to start at least......
Good Luck & let us know what you find out.
Just my .02, but if the wipers didn't work at all I'd say the motor got wet. Not stopping (parking) - I'd go for a true "daily double" Alex:
What is a bad circuit board? see posts #7 & 8
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Originally Posted by connecticut
Gotti, i just hacked your Myspace account; i explained to you the clogged udders were the 'cause' of the spent motor
I'll take 'smoked wiper motors for $500' Alex
when is the next CFNE event? i'll swap the motor out
hope i can wait that long.. whens the next event? I cant drive this car if it potentially rains or i gotta put the fuse back in lol.. pain in the rear!!!!!!!
