Switching Rims
Old Jun 15, 2006 | 06:55 AM
gmlefty's Avatar
gmlefty
Default Switching Rims
This may seem simple but are thier any problems putting OEM Z-06 rims on my 2004 coupe? Do they fit and will their be any rubbing issues or brake issues?
I like the wider rims and tires that come with the Z-06.
Old Jun 15, 2006 | 06:57 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
No issues. Go for it.
Old Jun 15, 2006 | 07:26 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
They fit just fine!
[IMG][/IMG]
jeff
Old Jun 15, 2006 | 07:27 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
A lot of people have done this, and, as the above post states, there have been no issues or problems. Good luck w/ the swap...
Old Jun 15, 2006 | 07:29 AM
JeffC5's Avatar
JeffC5
Another pic:
[IMG][/IMG]
jeff
Old Jun 15, 2006 | 07:31 AM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
No fit or rub problems. Great handling upgrade (especially if you add the Z06 swaybars as well). Only caution would be, if you have the F55 suspension the extra weight may cause the computer to throw codes periodically. It does not affect the performance of the system and is an annoyance only.
Old Jun 15, 2006 | 08:39 AM
They will fit just fine.
Old Jun 15, 2006 | 09:15 AM
Phat Ride's Avatar
Phat Ride
Are you referring to the new C6 ZO6 OEM (325/30/19) wheels and tires or the C5 version? If you are thinking about the C6 the OEM wheels will not fit properly as they will stick out beyond the rear fender by several inches due to the offset of the wheel, however if you purchase the ZO6 replica wheels in the same size, that are made for our C5 they will fit just fine and you can use the 325 width tire
Old Jun 15, 2006 | 04:53 PM
gmlefty's Avatar
gmlefty
Default Thanks
Thanks for the reply and also for the pixs. Now I definately like the wider rims & tires.
Old Jun 15, 2006 | 05:40 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
No Problems at all, I have the OEM's on my '03 Vert.
To Switching Rims
