Z-06 Calipers
Old Jun 16, 2006 | 07:37 AM
gmlefty's Avatar
gmlefty
Default Z-06 Calipers
I was curious if any forum members have installed the Z-06 calipers on thier coupe to replace the standard calipers. Will these fit with the standard thin spokes? Are there any clearance problems? do you need to replace the booster or Brake reservior or anything like this?
Old Jun 16, 2006 | 08:13 AM
GUSTO14's Avatar
GUSTO14
If you are referring to the C5 ZO-6 calipers, they are exactly the same as all other C5 calipers with the exception of the red paint. There are no clearance issues.
If you are asking about C6 ZO-6 calipers, that is a different matter and there are some clearance issues I believe. There are a number of members that have switched to the C6 ZO-6 caliper and if you do a search, you should find a lot of information on what might be involved with switching them.
Good luck... GUSTO
Old Jun 16, 2006 | 08:51 AM
jedicowboy's Avatar
jedicowboy
If you are just wanting red calipers then you should contact "corvettepilot" the forum vendor. Mike will powder coat them way cheaper than getting a new set. I believe he can also do custom colors.
Old Jun 16, 2006 | 08:56 AM
jedicowboy's Avatar
jedicowboy
here you go http://www.thepowdercoater.com
Old Jun 16, 2006 | 09:04 AM
gmlefty's Avatar
gmlefty
Default powdercoat VS paint
Yes, I have a C5 and I want to paint them. I was wondering if the
"do it yourself" caliper paint wears off quickly. I was thinking of painting with duplicolor caliper paint but would use powdercoat if there is marked improvement.
Thanks for your tips.
Old Jun 16, 2006 | 09:37 AM
81c3's Avatar
81c3
Default on a side note....
I love your avatar
Old Jun 16, 2006 | 10:21 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
Shameless plug,
There is a huge difference between my powdercoated calipers and painted ones. Many of the exchange sets I get back are painted, and they don't compare at all.
If you've got Millenium Yellow, I would go with matching calipers, like these:
Old Jun 16, 2006 | 10:24 AM
BUK VETT's Avatar
BUK VETT
I painted mine a year ago - don't waste your time. do the powdercoating. . . . . you'll be much happier.
Old Jun 16, 2006 | 10:28 AM
gmlefty's Avatar
gmlefty
Originally Posted by corvette pilot
Shameless plug,
Are the calipers aluminum? Do you use some sort of phosphate dip, how do you get it to stick to Alum?
What kind of backlog do you have for the powdercoat?
I would prefer powdercoat but hate to wait too long.
let me know corvette pilot
Old Jun 17, 2006 | 12:21 AM
0corvette pilot
Former Vendor
Powder is electrostatically applied. the part is grounded and the application gun is positively charged, the powder is attracted to the part and then cured at 400 degrees.
The wait for exchange is about 3 months, if you send yours in, I can usually turn them around in 2 days, maximum.
The price is $200 for calipers and brackets, plus $30 flat rate shipping, UPS ground. Other options available.
Exchange has a $200 core charge.
Old Jun 17, 2006 | 01:17 AM
chriswtx's Avatar
chriswtx
How are you prepping the aluminum? Sand blast, phosphate dip, etc...??
Old Jun 17, 2006 | 02:35 AM
edensknight's Avatar
edensknight
Shameless plug,
Effing Beautiful!
Old Jun 17, 2006 | 09:00 AM
0corvette pilot
Former Vendor
This is my normal prep:
Calipers:
Disassemble
Wash in solvent tank
Wash with simple green
Bathe in phosphate
Rinse/Dry
Brackets:
Wash in solvet to remove grease from sliders
Strip stock paint in muriatic acid
Bathe in phosphate
Rinse/Dry
Old Jun 17, 2006 | 10:22 AM
C5 ChemE's Avatar
C5 ChemE
I have the same car as you w/ Z06 calipers, brackets powdercoated by Mike, and chrome brake pad covers. If I did it again, I woulda had Mike done the whole thing! Matches perfectly for MUCH less!
Old Jun 19, 2006 | 08:32 PM
gmlefty's Avatar
gmlefty
WOW!!
I like those KUMHO's
I will probabley take mine off this fall and send to Mike for the MY Yellow and Black Lettering. Those look awsome Mike.
Old Jun 19, 2006 | 10:24 PM
RonJ's Avatar
RonJ
If I had a trailer queen that did the show circuit, I'd probably go the powder coat route, BUT, for $200 +, you can buy an awful lot of Dupli Colour or some such product. I painted my calipers over the last winter and I'm completely satisfied with the results. Bunch of miles on them since painting, no discolour and they wash up good with my wheel brush. They are just as bright and spiffy looking as the day I painted them!!
RonJ ...
Old Jun 19, 2006 | 11:32 PM
The Z06 calipers are the same ones as the coupe and vert calipers - only powdercoated red. Save yourself some bucks and just paint yours.
Old Jun 19, 2006 | 11:37 PM
b98's Avatar
b98
I would paint first, if not happy than powder coat.
To Z-06 Calipers
