A/C blows cold on passenger side only!!
Old Jun 16, 2006 | 10:11 AM
6500RPM's Avatar
6500RPM
Default A/C blows cold on passenger side only!!
I just recently picked up my 97 vette from the shop where they changed my starter and when I picked it up I noticed that the A/C was not blowing cold air. I picked up a can of r-134a thinking it was just low and then noticed that the passenger side blows cold air and the driver side blows warm air. I did a search on this issue and I tried disconnecting the battery for 60 seconds and no change. Could it be the HVAC control module? If it is how much will it cost and would it be an easy fix for me to do? Thanks.
Old Jun 16, 2006 | 10:26 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Are you getting any codes? Could be a few things....
Old Jun 16, 2006 | 10:37 AM
6500RPM's Avatar
6500RPM
I don't know how to check for codes on the DIC. Do I need to buy the code reading tool to check for codes?
Old Jun 16, 2006 | 11:04 AM
Bret01Z06's Avatar
Bret01Z06
Hold down options on the right side and hit fuel 4 times fast to get into diagnostic mode. It will cycle threw all the different categories and tell you home many codes it’s throwing for each one. You should have a HVAC code or 2 being thrown. What happened is the blend actuator in the dash for the dual zone ac has gone out. So it’s not blending the air correctly. My buddy’s 00’ FRC did the same thing.
Old Jun 16, 2006 | 11:06 AM
Bret01Z06's Avatar
Bret01Z06
Here is list of all the codes what they mean.
http://www.stengel.net/diccodes.htm
Bret
Old Jun 16, 2006 | 01:05 PM
JC in XTC5's Avatar
JC in XTC5
If the system reset did not fix it, then the actuator motor that controls the driver's side air-mix door is stuck. If it doesn't reset, then it probably needs to be replaced.
Old Jun 16, 2006 | 01:18 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
It is 9 times out of 10 the Temp valve actuator on the side that is not blowing cold. Part is usually around $100 but the labor will be more.
Old Jun 16, 2006 | 11:34 PM
Bryan's Avatar
Bryan
If you have the auto climate A/C controls.With your car runnning and a/c on,pull out fuses 18 and 27 on the passenger side fuse panel.Wait about 1 minute then place them back in the panel.This will recalibrate the damper motors if thats the problem.
My '97 did the same thing when they disconnected the battery to install my stereo.I did this and fixed the problem...
Bryan
Old Jun 16, 2006 | 11:59 PM
jrose7004's Avatar
jrose7004
When mine did that a can of 134a did the trick.
Old Jun 17, 2006 | 05:35 AM
Chris.Shea's Avatar
Chris.Shea
funny but this always come up as the cure. sure it could be a 100 little things but the one you most commonly overlook is the one.
Old Jun 17, 2006 | 11:16 AM
6500RPM's Avatar
6500RPM
I did find 2 HVAC codes B0361-H & B0441-H. Both codes had the (H) at the end meaning history code but no current codes. I do have the 1997 manuals so I was able to se that the codes were for the actuator. I wanted to try disconnecting the battery one more time before I sent to the dealer but this time for 30-40 minutes. It worked!!! The A/C blows cold on both sides. Thanks guys for all of your help.
Old Jun 17, 2006 | 11:50 AM
Dragon-Vette's Avatar
Dragon-Vette
Old Jun 17, 2006 | 07:20 PM
VinceC5's Avatar
VinceC5
Default usually low freon
happened all the time to me until fixed the leak at the compressor
Old Jun 18, 2006 | 02:43 PM
JC in XTC5's Avatar
JC in XTC5
Yeah, but when only one side of the dash vents blow cold, that does NOT point to a refrigerant issue. The plumbing in the dual zone AC is split into two sides so if only one side is cold, the issue is the air mix door on the warm side. Just an analytical approach.
Old Jun 18, 2006 | 02:54 PM
MyVetteDream
GLad you got it fixed
Old Jun 18, 2006 | 06:51 PM
dyal980's Avatar
dyal980
Old Jun 18, 2006 | 07:23 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
same here
To A/C blows cold on passenger side only!!
