key fob question
Old Jun 16, 2006 | 03:31 PM
brokebyducati's Avatar
brokebyducati
Default key fob question
I feel stupid even asking this, but if you pull your key fob apart to replace the battery, will it need any reprogramming of any sort or will it retain the codes, etc.
Old Jun 16, 2006 | 03:35 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
it'll need to be re-synced. The simple way is to hold both the lock and unlock buttons for about 15 seconds (near the car), which should cause the horn to beep if successful. If this doesn't work then you'll have to go through the process of learning the FOBs - I believe the owners manual has both proceedures in it.
