I've decided to try the eDead v1se as I will be updating my stereo. I have frost king in the rear now. I havent tried to pull it out, but has anyone here done it? Is this gonna be a challenge? Anything I should know?
Oh, and anyone know how to pull off the panels around the rear speakers and the roof? I'm afraid to pull to hard.
I havent done that yet and will add it to the list! Thanks for the advice.
I'm trying a material cloaser to dynamat. I know everyone says frost king is the best, but i swaer i got better results in my camaro with dynamat. I guess I'll have to learn the hard way myself.
Did the Frost King and the wells. Good reduction. Kinda wonder how wet that batt insulation gets after a good shower but...
Why replace the FrostKing? It's pretty thin. Just go over it?
...hmmmm ...you do have a lot of spare room for doubling insulation...
I doubled some areas in the front and back with Frost King and still had room especially in the back
Hey Stuz, I got my wheel wells done and drove 510 miles RT to BG2006 on Saturday. Big difference. Your pix were great. I filled every nook and cranny I could find with FK and batt insulation. I'm thinking about doing the inside back as well. It can't hurt, but I won't get the same %age of noise reuction again.
Excellent!
...the only problem I see with trying to do the back is that it is exposed to the elements more than the wheelwells...
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
No, Frost King is not the best - it's just the cheapest. I did the complete Frost King/Reflectix mod (with Dynamat Extreme in the doors) and I'm now doing something "a little different" with eDead. But this will be for my stereo - not for road noise.
I was thinking of going with B-Quiet, I know the stuff will do a good job of deadening sound but, my main concern is the heat AND added weight. With what I have read about the results with Frost King and Reflectix, I think I'll go that route...seems like a good compromise.
I did the Frost King mod with 3 small packs of Dynomat Extreme. I put a small patch of Dynomat on each flat surface I could. Some were large (6 inch x 6 inch) some smaller. I would test each section before and after by knocking on them and the dynomat areas would have a thud after I was done. Then I covered with Frost king and double many areas that that I could and I am very pleased with the results. I also put Frost King and Fiberglass insulation under the fender liners and also noticed a difference. Over all I am very please and the total cost was reasonable and the minimal added weight was minimal.
I been thinking of removing the door panels and the front fender liners but I don’t think they will make as big a difference like the rear section and cabin did. Has anyone done these areas yet and are you pleased with the results?
I used Hushmat in the door panels and in the cockpit and r-19 insulation with reflectix in the rear wheel wells and tunnel (thank you E.T. where ever you are), along with getting rid of the run flats. I can now carry on a conversation or talk on the cell without yelling.
