[Z06] CT Corvette cam package, $1795 installed
TSP Comp Cam(any grind) www.texas-speed.com
TSP PRC dual springs/Titanium retainers/seats/seals
TSP Hardened chromoly pushrods
TSP ported LS6 oil pump(subtract $120 if not required)
Powerbond underdrive pulley/new belts
GM LS2 timing chain
GM gaskets/crank bolt
NGK TR55's
Dexcool coolant
Mobil 1/AC Delco filter
$1795 installed/$1650 w/out ported pump and timing chain
$3395 above parts w/ TSP CNC'd LS6 heads
(above pricing is with TSP sourced items; any head/cam combo installed ie: etp, afr, call for details)
optional items(rates quoted are with cam install)
CAI(cold air intake) ie: Callaway/Blackwing/Halltech: no charge
Headers installed: $200
LS6 intake install(97-00 cars): $75
Innovate Motorsports LC-1 w/ XD16 gage: call
DTE Stage 2 differential installed: $1995 w/exchange
http://www.dynotech-eng.com/dte_c5_diff.htm
need a motor/transmission/diff/clutch/ swap?
this Z06 now makes 660rwhp from an A&A forged 346/D1 Procharger we installed a few months ago, has traction issues at the top of 3rd gear
I assume you do this yourself - at home or shop? What is the turnaround time assuming you have all the parts on hand? Will it run like crap without a tune? What part of CT are you in? Thanks!
I've had MS3's fire right up and drive 3 hours back to the Cape(Mass), I'm working with a local dyno(dynojet 224) and should have a solution for a complete tuned package in the future
the TSP combo with the MS3 will typically yield 430-440rwhp(M6 3.42's)
How soon can you do this, Id like to drive up to CT in the am and bring it back to LI that PM. Possible?
How do you feel on the new MS4 and a weekend car?
Keep me updated when you get a ms4 kit.
Just talked to Jason@TSP, they are expecting shipment of the MS4 grind any day
