MN6 - shifting, grind?
Old Jun 19, 2006 | 08:37 AM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
Default MN6 - shifting, grind?
I've got a 2000 FRC MN6 (obviously:-) with 11500miles on it and have been having an annoying shifting problem. When I least expect it and always in 1st gear; I will have come to a stop, shifted into 1st gear - then as I begin to release the clutch to pull away, I'll get one heck of a grind and vibration until I realign, redo the shift into 1st. What really bothers me, it sometimes happen in heavy traffic which could be dangerous. The problem is quite random and doesn't happen every-time I take the Vette out.
What am I doing wrong? Is it the trans? Any help will be appreciated.
Old Jun 19, 2006 | 08:38 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Bent shifter fork???
Peace
Willfulone
__________________
..................Click for
Old Jun 19, 2006 | 08:47 AM
maukavette's Avatar
maukavette
Could be the normal "marbles in a can sound" sound that our MN6's have from the clutch throwout bearing. Sounds a bit like grinding on mine too, but I have been reassured it is normal, and I ignore it now. It is even described on the owner's video. I've owned my 02 since Feb, so I will let someone more experienced confirm. Congrats on the C5!! Jon
Old Jun 19, 2006 | 11:37 AM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
I always put my car in first gear twice. First, to shift into first from a standstill. Then I take it out of gear and put it back in gear to make sure it is fully seated in gear. Then I let off the clutch to go. I do this because sometimes it feels like it is in 1st all the way when its not. Let off the clutch and grind. So I do 1st gear twice to make sure and avoid grind! Just my .02 cents
Old Jun 19, 2006 | 11:40 AM
INaband's Avatar
INaband
CI 7-8 Veteran
Old Jun 19, 2006 | 12:18 PM
JTJ's Avatar
JTJ
Thanks for the advise--I've done that, but not as a matter of habit. Will definitely try it!
To MN6 - shifting, grind?
