[Z06] Weird Problem
Old Aug 29, 2001 | 05:57 PM
Ricker812's Avatar
Ricker812
Default Weird Problem
My exterior temp display is stuck at 69 degrees, the climate control works fine, just the exterior temp always shows 69. I'd take it into the dealer but there is nothing else wrong with the car so I don't want to take it in only for that one thing, anybody got an idea of where I can start looking ?
Thanks,
Rick out.
Old Aug 29, 2001 | 07:08 PM
wstory1's Avatar
wstory1
Default Re: Weird Problem (Ricker812)
The sensor for the external temperature is on the passenger side of the radiator opening in the front of the car. Check and make sure you're got a good connection. The sensor can be removed for testing or replacement fairly easily. To test the sensor, measure the resistance through it and then heat it up and cool it down. You should be able to watch the resistance change with the temperature. If it doesn't change or if there's infinite or no resistance it's time to replace the sensor.
