Error Code C1243 - Need help!
Old Jun 20, 2006 | 09:12 AM
jwilliams67's Avatar
jwilliams67
8th Gear
Default Error Code C1243 - Need help!
I purchased a 1999 Corvette about a year ago and shortly afterwards starting getting the Service ABS, TC and AH messages with a trouble code of C1243 BPMV Pump Motor Stalled. After checking a few things I purchased a used ABS from e-bay and had a shop install. No problems for 6 months. I'm now getting the service ABS, TC and AH with the same code - C1243 again. It pops up as soon as I start the car when the engine is cold and occasionally when I hit a bump in the road. I've checked the grounds in the engine compartment and everything is clean. Any ideas what else might be causing this? Thanks!
Old Jun 20, 2006 | 09:31 AM
bozo4onion's Avatar
bozo4onion
This sounds like a ? for C5 Tech. Good luck.
