1 to 4 shift ????
Old Jun 20, 2006 | 11:52 AM
gtsvette's Avatar
gtsvette
Default 1 to 4 shift ????
i saw a little light in my fathers 99 corvette. what is the 1 to 4 shift ? and how do u activate?
Old Jun 20, 2006 | 12:14 PM
SteveL4446's Avatar
SteveL4446
Unless someone has installed something called a CAGS bypass, the 1st to 4th system is always active. It essentially forces you to shift from 1st to 4th in an effort to save gas and thereby avoids the gas guzzler tax. Most see this as an annoyance and either just "drive through it" by getting the engine rpm's up, or deactivate the system by putting in the "Computer Assited Gear Selection" (CAGS) bypass device.
Old Jun 20, 2006 | 12:16 PM
BT-01-vette's Avatar
BT-01-vette
cags elim. switch plug....got mine from Zip Corvettes
Old Jun 20, 2006 | 12:19 PM
corvette-pilot's Avatar
corvette-pilot
I think you only need to go about 15MPH in first to over ride it.
Old Jun 20, 2006 | 12:22 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
if you are seeing the light, but are still able to shift from 1st to 2nd when it is lit, then you already have a CAGs eliminator installed. You do not want to reactivate this feature - it is a pain.
Old Jun 20, 2006 | 12:36 PM
Frozenfire's Avatar
Frozenfire
Just wind it up a little more in 1st and it will disengage. Not a problem here.
Old Jun 20, 2006 | 01:07 PM
rwsr50's Avatar
rwsr50
Ohhhh boy! If you're seeing that light, you really did it now! You broke your Dad's Vette! You're in a heap o' trouble now!!!
Old Jun 20, 2006 | 01:16 PM
CVG323's Avatar
CVG323
i dont have a cags, and its a little hard sometimes to shift into 2nd, but i do it anyway... i thought something was wrong with my tranny when i shifted from first to second and ended up in fourth
Old Jun 20, 2006 | 01:22 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
A CAGs eliminator is fairly cheap, and it is real easy to install - I know it is easy enough to shift around the CAGs, but why would you when a simple fix is available?
Old Jun 20, 2006 | 01:25 PM
tknight4305's Avatar
tknight4305
Does it not hurt the trany to shift through those gears???
Old Jun 20, 2006 | 01:58 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
They are under $20.
Old Jun 20, 2006 | 02:02 PM
sailohio's Avatar
sailohio
DE-activate is the way to go. It really sucks. I got did mine last winter. It is a much more enjoyable tranny now.
Old Jun 20, 2006 | 02:24 PM
steve8's Avatar
steve8
Cags eliminator is a very worthwhile and cheap fix. Some people will disagree and say just go over 19 mph and you're all set, but there are plenty of low speed applications where it comes in handy. I believe you can cause damage by forcing it into second if it wants to go into fourth. Get the cags eliminator.
Old Jun 20, 2006 | 02:29 PM
cb5300's Avatar
cb5300
When I had my '01 and '04 tuned, I had the 1 to 4 shift turned off in the computer...easy enough, didn't have to unplug/buy anything extra. Everything has worked great since.
Old Jun 20, 2006 | 02:34 PM
HHC5's Avatar
HHC5
Old Jun 20, 2006 | 02:35 PM
SSDrew's Avatar
SSDrew
http://secure-order-server.net/caull...rame=&cart_id=
Old Jun 20, 2006 | 05:02 PM
c5coast's Avatar
c5coast
This is the first time I've heard that it can be turned off in the computer. Can any tuner do this? From another Mag Red II
To 1 to 4 shift ????
Old Jun 20, 2006 | 07:30 PM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
The 1 to 4 is a major pain that seems to activate when you least expect or need it
Old Jun 20, 2006 | 08:37 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The 1 to 4 shift exists to help GM meet their CAFE requirements.
When this light comes on,
you can only shift from
FIRST (1) to FOURTH (4)
instead of FIRST (1) to
SECOND (2). You must
complete the shift into
FOURTH (4) to deactivate
this feature. This helps
you get the best possible
fuel economy. After shifting
to FOURTH (4), you may downshift to a
lower gear if you prefer.
This light will come on when:
0 The engine coolant temperature is higher than
0 You are going 15 to 19 mph (24 to 31 km/h) and
You are at 21 percent throttle or less.
Old Jun 20, 2006 | 09:07 PM
Old One's Avatar
Old One
It's a warning that you are driving incorrectly.
