shifting
Old Jun 20, 2006 | 09:43 PM
Dans 98 corvette's Avatar
Dans 98 corvette
Default shifting
If i'm coming to a red light, is it better to put the car in neutral or downshift? I've heard so much controversy over this and i was wondering what you guys think thanks.
Old Jun 20, 2006 | 09:54 PM
AEVetteman's Avatar
AEVetteman
St. Jude Donor '06
I am in no way an expert. If coming to a red light, I will put it in neutral and brake to the light. But, if I was in a corner, downshift and hold those rpm's...
Old Jun 20, 2006 | 09:55 PM
Dans 98 corvette
okay thanks all info helps
Old Jun 20, 2006 | 10:01 PM
StealthZ06's Avatar
StealthZ06
I put it in neutral when braking.
Old Jun 20, 2006 | 10:06 PM
Cat Eye Blue's Avatar
Cat Eye Blue
That's the way I do it. Coming to a red light....put it in neutral. Coming up to a corner....downshift and then grin like hell!!
Old Jun 20, 2006 | 10:07 PM
AEVetteman's Avatar
AEVetteman
St. Jude Donor '06
Thanks, Cat Eye Blue...
Old Jun 20, 2006 | 10:16 PM
SearayC5's Avatar
SearayC5
Me personally, i like to downshift to save the brakes. I rev to match the R's and it's smooth as glass. I like the assistance the transmission gives especially on a down hill stop. Also there is less brake dust when u downshift and help the car slow down first. Just my .02 cents.
Old Jun 20, 2006 | 10:32 PM
DaBoz's Avatar
DaBoz
Me thinks that brakes might be cheaper to replace than a clutch... I could be wrong.
Old Jun 20, 2006 | 10:36 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
Old Jun 20, 2006 | 10:43 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I like to downshift, but not all the time
Old Jun 20, 2006 | 10:45 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Well you see...It all depends on what kind of mood I'm in...
Peace
Willfulone
__________________
..................Click for
Old Jun 20, 2006 | 10:51 PM
viper8u2's Avatar
viper8u2
Peace
Willfulone
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
I used to work at AAMCO Transmissions and had this conversation with my Boss. He simply pointed out the fact that the Brakes are CHEAP as compared to a clutch job.
Chris
Old Jun 20, 2006 | 10:53 PM
Tino's Avatar
Tino
Chris
Old Jun 20, 2006 | 10:55 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Peace
Willfulone
Sounds good to me
Old Jun 20, 2006 | 10:57 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Habit has me downshifting most often....
Old farm kid habit..
When I engage my brain, I realize that yes, brakes are cheaper...
Smooth shifter no matter what... I like the performance of the 6 speed offering...
Drive on!!
Old Jun 20, 2006 | 11:00 PM
BltByKrmn's Avatar
BltByKrmn
If you know how to downshift correctly there should be no serious wear on your clutch or syncros.
I leave the clutch out until just under 1k rpms. Whether I downshift or not is the only thing that is the real factor. Coming to a light in 4th? I'm not downshifting. Coming to a light in 5th? I'll downshift. I always downshift for turns.
To shifting
Old Jun 21, 2006 | 07:02 AM
I don't put it in neutral - I just press the clutch in and use the brakes. Never know when you might need the car in gear for an emergency maneuver,
Old Jun 21, 2006 | 05:27 PM
longrodlx's Avatar
longrodlx
downshift if you can......its not going to put any noticable stress on your clutch. its healthy for the car
Old Jun 21, 2006 | 05:32 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
What is this neutral that you speak of????
