Interior cabin noise
Old Jun 21, 2006 | 12:01 PM
Vetteman3's Avatar
Vetteman3
Default Interior cabin noise
It has been about 8 months since I have driven my C5 coupe...I drove it on a highway today...It felt great to be back behind the wheel but I have to tell you that I do not miss the interior cabin noise. Can anyone out there please give me some ideas on what I can do to reduce this noise???
I also am hearing wind noise from the drivers side window towards the rear...Has anyone had any luck regarding stopping this noise? Will a simple weatherstripping change solve this issue???
Thanks for your help!
Old Jun 21, 2006 | 12:30 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you are running the O.E.M. GY EMT's, that is a major contributor to the road noise. There are many aftermarket tires that even offer the extended mobility (though not the 200 miles that the GY EMT does) that are quieter.
Here is an interesting article about run flats as they are commonly referred:
http://www.corvetteactioncenter.com/....php?qstId=515
You can also install DynaMat or Frost King insulation into the interior that will reduce some of the noise as well.
Here are some links to previous threads that I found by utilizing the search function and using "road noise" as the search criteria.
http://forums.corvetteforum.com/show...ght=road+noise
Old Jun 21, 2006 | 12:48 PM
bozo4onion's Avatar
bozo4onion
Road noise? Tires, tires tires. Frost king insulation looks way time consuming to me for little claimed decibel change. Did I mention tires??? Wind noise? Ckeck rubber seals. My rear hatch (not roof) seal was deforming when I closed the hatch right behind my left ear. Window alignment is a notorious culprit also. G'luck.
To Interior cabin noise
