Really silly interior removal question...
Old Jun 22, 2006 | 09:03 PM
lostinvt's Avatar
lostinvt
Default Really silly interior removal question...
I could do this on all of my other cars in my sleep...but Im still a bit gun-shy about taking my vette apart without getting some guidance first...
I am going to be installing a new handsfree kit shortly and want to mount the mic on or near the rearview mirror. Im assuming the best way to get the wiring there is to snake it inside the headliner and down inside the a-pillar. How is the best way to get the a-pillar trim off?
Thanks in advance!
Old Jun 22, 2006 | 09:06 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Shouldn't have to take it off....plenty of room to snake it down between the A pillar and windshield.
Remember...its a GM product...FIT and finish isn't their strong point.
Old Jun 22, 2006 | 09:09 PM
YELLOHHH's Avatar
YELLOHHH
Amen, brother.
Old Jun 22, 2006 | 09:19 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
To answer your question - the cover on the A pillar just snaps on and off. Grab it with both hands and gently pull on it.
Old Jun 22, 2006 | 10:11 PM
Adrian-S's Avatar
Adrian-S
A quick related question, the trim piece st the top of the windshield that has the sun visor clips on it, has anyone taken that off, and is it an easy pop-off with a pull or screw removal?
-adrian
Old Jun 23, 2006 | 08:52 PM
lostinvt's Avatar
lostinvt
Thanks all...so how is it to snake the mic wire under the headliner?
Old Jun 24, 2006 | 08:24 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I've had to replace one of my A pillar trim covers. These are held on by 3 or 4 metal clips. You have to have the door open. Start at the top. Get your fingers under the edges and give it a tug. Gently at first, then slight increases until the first clip snaps loose. Then work your way down to the bottom. The bottom portion has a slot that fits around a peg. Reverse the process to put it back on. Start at the bottom and pop the clips back into the A pillar.
Good Luck
To Really silly interior removal question...
