Broken idler pulley
Old Jun 26, 2006 | 09:55 PM
The New Black's Avatar
The New Black
Default Broken idler pulley
Is there a bracket that holds the pulley right by the power steering pump? I'm looking at the diagrams and it looks like it just bolts up to the block. The problem is it snapped the aluminum it was attached to. I'm hoping it's part of a bracket, but I'll find out later when I get down to it. Anyone else have this problem?
Old Jun 27, 2006 | 12:51 AM
GrayC5's Avatar
GrayC5
The main drive belt idler pulley should bolt to the generator/power steering pump bracket. If you will update your profile with the model year, vehicle type (coupe, vert, FRC/Z06) and other pertinent info on your car, one of the members here who has the parts list for your model year may be able to provide you with part numbers.
Good luck with the fix.
Old Jun 27, 2006 | 01:33 AM
The New Black
Ok, thanks for the help. It's hard to see in their and I figured it had to be part of a bracket. I'm in a 2000 coupe.
To Broken idler pulley
