a little odd...(engine power reduction!)
Old Jun 27, 2006 | 12:15 PM
glennxx1's Avatar
glennxx1
Default a little odd...(engine power reduction!)
or something along those lines, happend when i first crunk my car up after it sat for about 5 days, inside my garage. it said service traction control system, i cleared the faults it still had service engine soon light on, but no power reduction, then i parked the car for 5 minutes started it back up, ses was gone and no more trouble out of it....any ideas?
Old Jun 27, 2006 | 12:20 PM
VetterGetIt's Avatar
VetterGetIt
I sure don't know, but I would love to. That is the kind of thing to make you go bananas worrying about it. let's hope for a good tech, plus you might want to post this in tech.
Old Jun 27, 2006 | 12:44 PM
wpdjoey's Avatar
wpdjoey
happened to my 02 ...a couple days later after driving that night started fine in the am got the warnings then reduced power mode was on vacation so had to have it towed to the nearest dealer,long story short 4 days laterthey installed a new battery the glass mat battery was discontinued by gm ....no problems since
Old Jun 27, 2006 | 01:06 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Any time something like that happens, the computer stores information to diagnose the problem - we call these Diagnostice Trouble Codes (DTCs) or just codes. By pressing a special sequence of dash buttons, you can have these codes played back for you. Here is a tech tip on how to pull the codes, and what they mean
Old Jun 27, 2006 | 02:33 PM
DPG's Avatar
DPG
St. Jude Donor '06
had the same thing, all i had to do was tighten the battery cabels at the battery and i was good to go
Old Jun 27, 2006 | 03:28 PM
glennxx1's Avatar
glennxx1
ty for all the input, hoping it was nothing
Old Jun 27, 2006 | 03:48 PM
edensknight's Avatar
edensknight
A very important service reminder: Loose BAT connections may induce low voltage fluctuations which may then cause your your DIC to throw numerous trouble codes. Hence, do tighten all connections, BUT, also, check BAT for any leaks, then, clear codes. Low BAT voltage fluxations may cause everything from faintly readable A/C Radio controls, AH/TC, and, BCM trouble codes to the dreaded "Service Column Lock" DIC prompt.
Old Jun 27, 2006 | 03:57 PM
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
In laymen's terms:
I had the car go into low voltage condition a number of times which shuts the car down given the computer does not have juice to run.
This had to do with a racing setup where I was not getting enough charge from the alternator to keep the battery charged. Once corrected no further problems.
To a little odd...(engine power reduction!)
