I have had my 01 Vert for a few months now and I want to take the wheels off and do a clean up on the inside of the wheels.
I purchased some 2x10x8 for the homemade ramps that I got here on the forum.
I bought a hydralic floor jack and some jack stands. I have read all the info for raising the car.
I'm not much of a mechanic. I will probably be just changing my own oil and taking the tires off now and then.
I am looking to buy a Torque Wrench and there are so many different kinds and ft. lb. ranges. I just wondered which one would be an all around Torque Wrench you guys are using.
I would like to get a good one. I have been looking on Ebay and the Snap-On wrench's seem to be the best, but then again which drive? 1/4", 1/2", 3/8". What torque range? 10 to 150 lb. 25 to 200. 40 or 50 to 250? Too many choices!!!
I'd get the 1/2 inch drive with up to 150 ft lbs measurement. That should cover just about anything you plan to do.
Dittos - but be sure to get a wrench with the longer handle. Some shorties are about 12 inches long - for the tires, a 21 inch wrench is easier to handle...
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
I bought the 1/2' Husky from Home Depot...goes up to 200. 4 years ago a buddy was tightening my wheels and did something to the wrench and the next thing we know, there were springs and parts everywhere...damn thing came apart. Walked into Home Depot (no reciept 2 yr old purchase) with all the parts and they literally took one off the shelf and handed it to me...no questions asked...part of Husky's lifetime warranty program...haven't had any problems since. Then again my buddy hasn't beed allowed to get near my tool box since then
I'm going to go against the other suggestions here and say get a 1/2" beam type torque wrench. They are cheap, remarkably accurate and easier for the newbie to use. Chuck.
I picked up from E-bay a ½ Mac Cordless 150 ft-lb. I wanted an Electric but got such a deal on the cordless I had to take it. It’s working out great for me so far, take off wheels with no issues at all I use it on my Tundra as well with no issues. I also picked up a set of Snap on impact sockets on e-bay and again great prices. You will need a good torque wrench as well if you don't already have one I have a ½ Mac....
Before you know it you will be doing brakes etc.. Good luck.
Hahaa! Same thing happened to my friend exactly!
I don't think anyone mentioned the difference between wrenches (i.e., click type or bar (pointer) type). For best accuracy and lasting calibration, the pointer type is best; simple design. Click types are good and convienent as well but more moving parts to wear causing loss of calibration sooner. I've had my bar/pointer wrench over 30 years; it continues to remain quite accurate
If you aren't much of a mechanic, no need to get over 150# wrench as you'll never run into any fasteners requiring more torque than your lug nuts.
That's what I have, and it has met all my needs! Luckily, I even found one at Harbor Freight Tools for such a ridiculously low price I had to buy two and give one as a gift to a friend.
Another point to remember is most torque wrenches are accurate from 20% of their maximum capacity up to their maximum capacity. Thus a torque wrench rated for 150 ft. lbs. would NOT be considered accurate below 30 ft. lbs. Thus, you typically need a smaller torque wrench to handle many of the bolts/plugs/etc. on a C5.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I bought a Husky 1/2" drive wrench. I'm very happy with it and the price was good. As Gary accurately advised - when you are finished with the wrench - take the tension off the springs and place it back into it's case. A Torque wrench is a precision instrument and should be treated as such. It should not be used like a ratchet to remove fasteners or to tighten them - it should only be used to torque the fasteners. Also - it should be calibrated (depending on the amount of use it gets and the way it is handled) every couple of years.
