Hatch adjustment
Old Jun 30, 2006 | 01:32 AM
moserbe's Avatar
moserbe
Default Hatch adjustment
The hatch on my 98 coupe is in need of adjustment. The driver's side all of a sudden is about 3/16" higher than it should be. I have looked at the assembly but do not see where it can be adjusted to lower the corner. The rubber stopper is where it is supposed to be. Can anyone give me the proper procedure? I do not have a body manual for the car. Any assistance will be appreciated. Want it to be perfect before I take it to the Carlisle fun field.
Old Jun 30, 2006 | 11:43 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
if your off 3/16 on driver side...(I assume the rear most corner)
...and you havent changed the driver side rubber bumper...
then...raise or extend the length of the passenger side and see if it doesnt create a counter force to lower the left side...
...otherwise ...lower the passenger side...
Old Jun 30, 2006 | 02:39 PM
edensknight's Avatar
edensknight
What Stu said!
To Hatch adjustment
