Sagging drivers door
Old Jun 30, 2006 | 11:54 PM
ronssito's Avatar
ronssito
Default Sagging drivers door
Just purchased a 99 FRC Hardtop and noticed a small problem. The drivers door sags slightly so that it doen't mate with the latch mechanism in the jam properly. The passenger door closes perfectly. There are no air or water leaks.
Is this normal on these cars?
Can I loosen the hinge bolts and raise the door slightly?
Old Jun 30, 2006 | 11:57 PM
vetred's Avatar
vetred
I did have that exact problum and a few more! I bought an extended warenty so I had the dealer fix that, and replace the door seals and window seals and Im damn glad I did! and ya I have the "99" F.R.C.
Old Jul 1, 2006 | 08:26 AM
Cajun99's Avatar
Cajun99
I haven't had any issues with door or body panel alignments.
All is well
Old Jul 1, 2006 | 09:07 AM
Tom/99's Avatar
Tom/99
No issues with door or body panel alignments, on my coupe.
Old Jul 1, 2006 | 12:10 PM
VetterGetIt's Avatar
VetterGetIt
None here either. My doors close like a Mercedes, its so smooth and sounds great when you close it (no rattle at all).
Old Jul 1, 2006 | 12:23 PM
JC in XTC5's Avatar
JC in XTC5
Yes, the door hinges allow for adjustment and the procedure is in the service manual. It's unclear whether this can be done without removing panels.
To adjust the door up/down, you need to loosen the set of hinge bolts on the pillar side one at a time and move the hinge, not the door. Then retighten the hinge bolts before loosening and adjusting the other hinge.
1 - Loosen upper hinge to the hinge pillar bolts.
2 - Reposition hinge up to raise the door or down to lower it.
3 - Tighten the upper hinge bolts (22 lb. in.)
4 - Repeat for lower hinge.
The door can also be adjusted in/out by doing the same procedure on the door side of the hinge.
Old Jul 1, 2006 | 12:34 PM
ronssito's Avatar
ronssito
Thanks...I'll try it!
Old Jul 1, 2006 | 09:44 PM
ronssito's Avatar
ronssito
Door fixed...thanks Corvetteforum
Old Jul 1, 2006 | 09:48 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Old Jul 1, 2006 | 11:18 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old Jul 1, 2006 | 11:44 PM
JC in XTC5's Avatar
JC in XTC5
To Sagging drivers door
