Threw a Code-What is it? HELP
Old Jul 2, 2006 | 07:17 AM
vettpapaw's Avatar
vettpapaw
Default Threw a Code-What is it? HELP
My check engine light came on. Checked the code with my Hypertech. It says DTC is P1870. What is that? Found code from Vett Dr. It says "Transmission Component Slipping" DO I HAVE A PROBLEM? Car and Trans.(A4) seems to be fine.
Thanks "Wild Bill" from 40769
Old Jul 2, 2006 | 09:06 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Check your trans fluid level.
Slipping tranny is never good reset the code see if it comes back.
Old Jul 2, 2006 | 09:08 AM
Vassili's Avatar
Vassili
From what I understand you can't check your trans. fluid. Maybe post this over in the Tech blog....
Old Jul 2, 2006 | 09:11 AM
TomZ's Avatar
TomZ
Isn't it a sealed unit?
To Threw a Code-What is it? HELP
