For some reason my Easy Entry seems to be malfunctioning. When you place the key in the ignition all works fine, seat moves up, as does the tilt and the steering wheel.
But when I remove the key the seat no longer moves back, the steering wheel does, but not the seat.
I have tried reseting Easy Entry and reseting the memory controls.
Everything works except the auto seat move at key removal.
Mine does not do that, but I have always wondered why it sometimes resets to my Memory 1 when getting in the car, other times I have to manually push the Memory 1 button.
If you didn't unlock the car with the fob, it won't automatically reset when you put the key in and you'll have to push the memory button.
Thanks,
I tried this, the seat will not come up or go back on auto when the car is unlocked by the fob or with memory buttons.
All other easy entry/memory functions seem fine, just the seat track movement is dead
Was working yesterday
I was responding to Angela's questions as to why it sometimes works automatically and other times she has to press the memory button. Sorry, I have no idea why your's isn't working.
