Got a small problem
Old Jul 3, 2006 | 05:06 PM
turbota's Avatar
turbota
Default Got a small problem
Sometimes when I turn off my 98 vert A4 and I open the door, I get the warning chime like I left the lights on or key in when nothing was left on or in. Any ideas what might be causing this?
Nick
Old Jul 3, 2006 | 05:19 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There is a little pin/sensor in the ignition. Put a little graphite lube on the key and slide it in and out about a dozen times or so. This will lube the lock and the sensor, so it won't stick.
You can get the graphite in a tiny droplet bottle anywhere that sells locks.
Do not use oil, as oil attracts dust and is to thick. Graphite is made for things that lock.
Old Jul 3, 2006 | 05:35 PM
ALLEGRO's Avatar
ALLEGRO
For sure try the graphite method in the earlier post.
My guess is that it is a faulty ignition switch. Hope the lube helps !
To Got a small problem
