Be careful what you put on the High Polished wheels as they have clear coat on them. Some chrome polishes could potentially damage the clearcoat. Always read the label first!
BAD AZZ is correct. The polished wheels are clear coated.
SO once cleaned, they should be treated with a good wax or paint sealant... just like all painted surfaces on your car.
A sealant will last longer
Sealants include
Klasse AIO, Meguiars NXT,Mother's Reflections, Poorboys, Rejex, Zaino. etc
I prefer Rejex.
I used rejex and loved it on my polished 01's...I switched to z06 chromes and rejexed the whole entire rim before mounting...water just beads off and hopefully brake dust does the same
Since they are clearcoated, you can use the same wax on them as on the car's painted surface. When I had my set, I just used paste wax on them and kept them clean as much as possible.
