[Z06] Ac actuator issue
Old Jul 9, 2006 | 03:22 PM
MikeP's Avatar
MikeP
Default Ac actuator issue
My A/c keeps tripd codes to my DIC. I had the left actuator replaced twice and I have the same code on my Dic again HVAC 441,Left actuator out of range. When I do a manual DIC rading and try to delete it from the memory, I hear the system cycling the the actuators and vent doors. At the end of the cycle the system sets the same codes I just deleted. How many of you have had this problem? How many times did you go through this issue before the stealorship replace the AC control unit. I talked to mechanic who told me is that he just bends the actuator arm to keep from throwing codes which keeps the sysem in perameters. Not the answere I wanted to hear. Nothing worse that driving with a check engin lite staring me in the face. AC sysrem seems to work fine.
Mike
