Surging and hesitation
At any rate, the hesitation is almost non-existant. Pulls great, BUT,
when I pull the car had to 2500rpm or above and hit the clutch, the idle still bounces between 500 and 1000rpm. below 2500rpm, it returns to the normal 750-800.
Clogged injector(s)?
I put a cold air cover on a Blackwing years ago, except I made a much bigger hole, almost the size of the Blackwing, most of the area under the cover.
My car ('01 Coupe at the time) would barely run. Had to heel & toe just to keep it from stalling when slowing.
