alarm sets itself?
Old Jul 9, 2006 | 11:43 PM
fusion_ta66's Avatar
fusion_ta66
Default alarm sets itself?
I have a question about my factory alarm. Car in question is an '01 Z06. When I come home, I just shut the car off, get out, and close the door. I do *not* lock the doors in any way. If I come back out later on and open the door, the alarm goes off. Does the alarm set itself after a set period of time? Anyone know anything about this?
thanks
Joe
Old Jul 10, 2006 | 10:42 AM
fusion_ta66
anyone?
Old Jul 10, 2006 | 11:47 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Nope should not activate if you havrn't locked the doord. I do the same all the time and no alarm. Somethings not right.
Old Jul 10, 2006 | 01:13 PM
Railfan's Avatar
Railfan
My car does something similar. I can hear it locking and unlocking as I walk around the garage. Kind of annoying. I have gone through the usual DIC settings and fob settings, but it still does the same thing. I have no clue.
Clueless in Michigan
Railfan
Old Jul 10, 2006 | 01:17 PM
j84buick's Avatar
j84buick
Railfan
Sounds like the passive entry system that on the 97-99 models. Where it will lock/unlock for you. I thought you could turn it off though.
Old Jul 10, 2006 | 02:42 PM
Railfan's Avatar
Railfan
Yeah, I think you can. But I'm still learnin'.
Old Jul 10, 2006 | 02:48 PM
sailohio's Avatar
sailohio
My 2002 doesn't do that. Can you turn it off in the DIC?
Old Jul 12, 2006 | 11:21 AM
fusion_ta66
Ttt
Old Jul 12, 2006 | 11:35 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
You turn it on or off (the passive mode) by using the slider switch on the bottom of the FOBs, not through the DIC
Old Jul 12, 2006 | 11:39 AM
j99vette's Avatar
j99vette
the switch is on the fob. sometimes it gets stuck though and you have to take it apart and permenantly switch it off. the passive entry was stopped in 99 though. something definately is not right.
Old Jul 12, 2006 | 05:45 PM
Hammie's Avatar
Hammie
Railfan
That's because yours is a 99, and you have the PASSIVE switch activated on your FOBS.
Old Jul 12, 2006 | 06:01 PM
Z28TOZO6's Avatar
Z28TOZO6
I have an an 03 Z and mine auto arms it self after 15 minutes. I dont know if you can turn it off but my insurance company gives me a discount for it!
Old Jul 12, 2006 | 09:12 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I think GM discontinued this because of ongoing problems.
Bob
Old Jul 12, 2006 | 09:14 PM
Hammie's Avatar
Hammie
Bob
It's stated by the Corvette Black Book as being discontinued because some owners could not figure it out.
Is it that hard to figure out?
Old Jul 12, 2006 | 09:45 PM
Wes Brannon's Avatar
Wes Brannon
That was my problem
Old Jul 12, 2006 | 09:51 PM
tramminc's Avatar
tramminc
i've got the same car, mine doesn't do that. (hey don't leave your keys in the car )
Old Jul 13, 2006 | 11:37 AM
fusion_ta66
Still clueless here...........
Help!
To alarm sets itself?
Old Jul 13, 2006 | 12:03 PM
NotABlond's Avatar
NotABlond
Question - are you leaving your keys in the ignition when you vacate the car?
I have a 99, and I turned off all the auto/passive settings thru the FOB Options menu and from my Remote Transmitter.
Read the owners manual for the FOB and Remote Transmitter settings - it's a little confusing but just keep messing with it until you get it all figured out....
Old Jul 13, 2006 | 04:19 PM
HummelS's Avatar
HummelS
Nope - the car in question is an '01 Z06 - doesn't have the "passive" feature.
I'd be suspecting a weak battery is somehow screwing up the security system. It can cause some bizarre symptoms: on my 2002, when the battery was dying, the alarm would go off when I tried to lock the car with the fob.
Old Jul 13, 2006 | 05:05 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
OK, I know this sounds strange but are your floor mats wet - in this hot weather a lot of people have been having strange electrical problems lately - some of them are due to plugged AC drains, which can allow moisture to get into the electronics, causing all sorts of weird problems. Take the panel out in the pass side foot well and check for any dampness in there, just to be safe. Other than that, I too am clueless...
