[Z06] Brake Booster replacement, aftermarket?
Old Jul 10, 2006 | 11:55 PM
robertpel9's Avatar
robertpel9
Default Brake Booster replacement, aftermarket?
My 01 Z06 has the POS booster that does not return the pedal and is causing the brakes to hang up
I see i can get an aftermarket booster from Kellys or AAP fro less than 200 bucks. Will this be fine and do i need anything else. I see in the TSB that there is a seal as well. I assume i have to get this right from GM
Any tips from someone who replaced theirs would be very helpful. I assume this will fix my lazy brake pedal?? Then i'll just have a lazy clutch pedal LOL
Old Jul 11, 2006 | 11:41 AM
robertpel9's Avatar
robertpel9
TTT, anyone????
Old Jul 11, 2006 | 02:49 PM
DPG's Avatar
DPG
St. Jude Donor '06
ttt
Old Jul 13, 2006 | 07:01 PM
ChasNMe's Avatar
ChasNMe
had both 99 hardtop and 99 vert get the sticky pedal once, about a month apart, took it to the dealer and the vette mechanic said keep the fluid clean. ever since, no issues. i suck out the fluid at every oil change with a turkey baster, same on my 03Z. dont suck the reservoir all the way dry though or you could get air in the system.
$.02 jake
To Brake Booster replacement, aftermarket?
