lg longtubes with xpipe install tips
Old Jul 12, 2006 | 05:18 AM
BloodRayne's Avatar
BloodRayne
Default lg longtubes with xpipe install tips
gonna do the long tube header install today or tomorrow..Anything to look for while im there? Do i need to remove anything prior to putting them in? Do they install from top or bottom? I bought the system used so i have no instructions!
Old Jul 12, 2006 | 08:26 AM
97C5ENVY's Avatar
97C5ENVY
Check this out: www.ls1howto.com
Enjoy!
Old Jul 12, 2006 | 08:30 AM
chargedc5's Avatar
chargedc5
You will have to remove the Alternator and steering linkage (I believe its only one bolt) Twist and wiggle hear and there.
Old Jul 12, 2006 | 08:44 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
http://www.cajundude.com/longtubes.htm
Old Jul 12, 2006 | 09:44 AM
torchredfrc's Avatar
torchredfrc
huh? i didn't remove either of these to install the headers. Use ls1howto.com, the instructions there are very good.
Also, to get the drivers side in/out you really need the entire car about 20" off the ground. This is probably the most important step. You can get the passenger side in from the top w/o removing the starter but the drivers side must go in from the bottom. I'm thinking the drivers side may go in from the top if you remove the alternator/steering linkage though.
Old Jul 12, 2006 | 03:42 PM
chargedc5's Avatar
chargedc5
Huh, I just told him how I did it, and mine was not put in from the bottom on the drivers side, it was put in from the top (the only way it would go). I believe it matters what brand you have. I have texas speed headers and from talking to Jason they both go in from the top.
Old Jul 12, 2006 | 04:48 PM
torchredfrc
Yes, that does make a difference. The thread topic specifically says LG Headers.
Old Jul 12, 2006 | 10:53 PM
chargedc5's Avatar
chargedc5
My bad, I overlooked it I just read Long Tube Headers
To lg longtubes with xpipe install tips
