C5 Oil Change
Old Jul 13, 2006 | 02:49 PM
y2kvan's Avatar
y2kvan
5th Gear
Default C5 Oil Change
I just bought a 2000 Convertible a few months ago. Today was my first encounter with a Dealership Oil Change. $78.50. I change my own oil in my 81 Coupe and my 95 Bronco, but guess I'm a little intimidated with trying an oil change on my 2000 C5. What would be the best way to learn how to change my own oil. I have several questions/concerns:
1. Best Oil to use, and where to buy it.
2. Best way to get under the car, I've seen posts about Rhino ramps, where do you buy these and how much are they?
3. My main concern is how to reset the computer after an oil chance. Can anyone walk me through this reset process.
Thanks in advance for any help and/or advice
Old Jul 13, 2006 | 03:43 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
1. Mobil 1 10W30, WalMart, KMart, Costco
2.WalMart , around $30
3.Owners manual tells exact instructions to reset...or turn your key to "on" ,don't start and pump the gas pedal to the floor 3 times.
Just take your time changing oil...do it yourself and bond with your Vette..don't be a lazyazz...spend the money($35-$40 from what you said you paid) you save for a little effort on something else and know you won't get your Vette messed up by some goober mechanic at the stealership...greasy interior, sctatches on the outside,waste of your time taking it in waiting for it, etc...its simple...really
Heres something interesting for you...... new Corvette guy its been around for a while
Secrets of the C5
C5 Secrets and Computer CODE
The little yellow "helper light" on the bottom of the rear-view mirror that illuminates the shifter area
That you can put your key in the driver's door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
All of the option codes are in the glove box.
Tire inflation recommended pressures are on the driver's door(disregard this one...keep 30/31 hot in your tires..that means maybe 26/27 cold...or whatever it takes to do so... depending on the temperatures in your area)
The thing that looks like a little LED near the DIC buttons is a light sensor
The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun
The build sheet is in the front re-bar
If you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let you know you have old timers disease.
You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running)
Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you've traveled since last starting the engine.
Hold down the Active Handling button for 5 sec. to engage "Competitive Driving" on cars equipped with active handling (2000 and previous years must be stopped.)
If you pull the seatbelts all the way out while you're buckled in, they ratchet back in to hold you tighter into the seat.
Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not will not flash. Your front turn signals will operate normally, however.
The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment, behind the carpet and on the side of the car. Not that it really works well.
Also you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passengerÂ's side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an 'indent' that holds the wheel lock key.
If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
HUD has a shift light for manuals.
You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
You can eject the cd from the in-dash player without turning on any power. Don't even need key in the ignition.
The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
When the engine is shut off, you can get the odometer reading by turning on the parking lights.
You can program setting #3 (both memory buttons atonce) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
If you hate DRLs you can pull the e-brake ONE click and they go off
Old Jul 13, 2006 | 03:46 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Buy your own oil and filter. Take it to the dealer. Mine charges me $13.99 plus I get to watch. No more dirty hands and trying to dispose of the old oil!
Old Jul 13, 2006 | 04:01 PM
Silver98's Avatar
Silver98
Autozone and Advanced Auto will take your used motor oil... for free. Just don't use the vette to get it to them...
Old Jul 13, 2006 | 04:08 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...I wait till I go out for something ..shopping etc then drop the oil bottles off at Firestone...N/C
Old Jul 13, 2006 | 04:23 PM
cb5300's Avatar
cb5300
Old Jul 13, 2006 | 04:27 PM
VaTechHokie's Avatar
VaTechHokie
Default Agree with buying oil and filter taking to dealer, charged me $8, not bad
total cost with oil and filter $47
Old Jul 13, 2006 | 04:29 PM
steve8's Avatar
steve8
I don't know about a 2000, but my 04 takes 5w-30 not 10w-30.
Old Jul 13, 2006 | 05:50 PM
Tom/99's Avatar
Tom/99
I use a floor jack instead of ramps. Mobil 1 oil is sold at most department stores and auto supply stores. I buy my AC oil filters at AutoZone. Changing the oil in a C5, is really no different than changing the oil in any other car. The C5 takes 6.5 quarts with a filter change.
Old Jul 13, 2006 | 06:05 PM
Land Jet's Avatar
Land Jet
Default I'd do it myself but...
I'm scared to death to jack the thing up. The manual alludes to these round areas under the car but many of the center piston lifts as well as side lifts that I can use won't reach those points no matter how centered the car is. Say I actually had a lift that would reach, I probably still wouldn't do it because the illustration in the manual is shoddy and I'm confused about the location of the points.
Furthermore, about that 10w-30, the manual recommends 5w. It's what they put in it at the factory. If you lived in the desert maybe 10 because it would thin out so quickly.
To C5 Oil Change
