Was wondering what your coolant temp readings have been? Highest mine have got were 221 degrees. And that was a few weeks back with 116 degree temps outside Just leaving now to do some errands so i am going to monitor them. Supposed to be a scorcher today
As soon as the temp climbed above 120, I started monitoring the temps. The highest temps I witnessed were:
Oil: 232
Coolant: 221 (highest I've ever seen, same as you)
Tranny: 225
I love hearing that about dry heat! I have lived in the extremes for both dry and humid areas. Trust me, it doesn't matter if it is a dry heat or not, it is 115 everyday in phoenix with no rain or even clouds. In other locations, you can wake up with a nice rainy cloudy day. Try the 115 dry heat nearly everyday for over a month!
Yeah... it's hot hotter than a wet a$$, but I just keep thinking of January in western MN and it ain't so bad.
Peace.
Stephen
I moved here from the Twin Cities and when it gets too hot, I just remembering going home for Xmas a couple years ago and dealing with -20 temps (and that DOESN'T include the wind chill!)
The heat sucks, but it's still more tolerable than humidity or extremely cold winters; for me anyway!
Dry heat is a misnomer...105-115+ degrees with monsoon weather is hardly dry. There was a summer in the early 90s that we had 2-3 days of 120+ degrees!! Our company cars wouldn't even run in that temperature.
